DSL-2650U/RA/U1AEOL EOS
Wireless modem/router ADSL2+ 802.11n Desteği (150 Mbit/s) ve USB-port
Tanımlama
USB-port
The router is equipped with USB-port for connecting a USB-modem with which you can quickly connect to the Internet. In addition, you can connect to the USB-port on the router USB-drive, which will be used as a network drive, or a printer.
ADSL-port and 4-port switch, Ethernet WAN support
ADSL-router has a port for connecting to ADSL-line. Built-in 4-port switch allows you to connect computers equipped with Ethernet-adapters, game consoles and other devices to your network. In addition, any Ethernet-port devices can be used to connect to a dedicated Ethernet-line.
Security
Wireless Router DSL-2650U has a built-in firewall. Enhanced security functions minimize threats of hackers and prevent intrusions to your network and access to unwanted websites for users on your local network.
Wireless Interface
You can quickly create a wireless network at home or in the office, which will allow your employees or members of your family to connect to a wireless network almost anywhere (within range of a wireless network.) The Router can serve as an access point to connect to the wireless network devices of the standards 802.11b, 802.11g and 802.11n. The device supports several security standards (WEP, WPA/WPA2), filtering devices to be connected to MAC-address, and allows the use of technology WPS. In addition, the device is equipped with a button to disable / enable the Wi-Fi-network. In case of need, such as leaving home, you can turn off the router's wireless network at the touch of a button, while the devices connected to the LAN-ports on the router will remain in the network.
Easy setup and update
To configure a wireless router DSL-2650U uses a simple and user-friendly web-interface (available in several languages). Now you can easily upgrade the firmware - the router itself is a proven version of the software update server D-Link, and notifies the user ready to install it.
Genel Özellikler
Çözümler
Sipariş Bilgisi
Görseller
DSL-2650U/RA/U1A
View from the right
Front view
Back view
Front view
İndir
Destek Merkezi
