Hızlı Arama
Ürün Özellikleri:
Wireless modem/router ADSL2+ 802.11n Desteği (150 Mbit/s) ve USB-port
EOL EOS
Genel Özellikler:
Fiziksel Özellikler
Hardware
Interfaces
• ADSL: 1 port with an RJ-11
• LAN: 4-port 10/100BASE-TX Ethernet with RJ-45 auto-sensing polarity MDI / MDIX
• WLAN: built-in wireless interface standard 802.11b, g and n
• USB: USB 2.0 type A
Frequency band
2412 ~ 2484 MHz
Data transfer rate
• 802.11b: 11, 5.5, 2, 1 Mbit / c
• 802.11g: 54, 48, 36, 24, 18, 12, 9, 6 Mbit / s
• 802.11n
  ◦ HT20: 150, 130, 117, 104, 78, 52, 39, 26, 13 Mbit / s
  ◦ HT40: 150, 130, 117, 104, 78, 52, 39, 26, 13 Mbit / c
Transmitter output power
The maximum value of the transmitter power will vary in accordance with the rules of the radio-frequency regulation in your country
• 802.11b: 16,5 ~ 18,5 dBm
• 802.11g: 13,5 ~ 16,5 dBm
• 802.11n: 13,5 ~ 16,5 dBm
Modulation Schemes
• 802.11b: CCK (11, 5.5 Mbit / c), DQPSK (2 Mbit / c), DBPSK (1 Mbit / c), DSSS
• 802.11g: PSK / CCK, DBPSK, DQPSK, OFDM, BPSK, QPSK 16QAM, 64QAM
• 802.11n: PSK / CCK, DBPSK, DQPSK, OFDM, etc.
ADSL Standards
• ADSL: Multi-mode, ANSI T1.413 Issue 2, ITU-T G.992.1 (G.dmt) Annex A, ITU-T G.992.2 (G.lite) Annex A, ITU T G.994.1 (G. hs)
• ADSL2: ITU-T G.992.3 (G.dmt.bis) Annex A / L / M, ITU-T G.992.4 (G.lite.bis) Annex A
• ADSL2 +: ITU-T G.992.5 Annex A / L / M
Software
Types of WAN-connection
• 3G
• ADSL
  ◦ PPPoE
  ◦ PPPoA
  ◦ IPoA
  ◦ Static IP
  ◦ Dynamic IP
  ◦ Bridge
• Ethernet
  ◦ PPPoE
  ◦ Static IP
  ◦ Dynamic IP
  ◦ Bridge
Wireless network
• Standard IEEE 802.11n, device compatibility standard IEEE 802.11b / g
• WEP-encryption
• WPA/WPA2 encryption technology mechanisms TKIP, AES and TKIP + AES
• Access to a wireless network based on the MAC-address
• The PBC method of WPS
• Management of the connected devices
• Advanced Settings
Protocols ATM / PPP
• Ethernet encapsulation bridging and routing
• Multiplexing based VC / LLC
• ATM Forum UNI3.1/4.0 PVC (up to 8 PVC)
• ATM Adaptation Layer Type 5 (AAL5)
• Principles and functions OAM ITU-T I.610, including F4/F5 loopback
• ATM QoS
• PPP over ATM (RFC 2,364)
• PPP over Ethernet (PPPoE)
• Support for Keep-alive for PPP-protocol
Network Protocols and Features
• DHCP-server/klient/relay
• DNS relay
• Dynamic DNS
• Static IP-routing
• Remote access
• Network statistics for each interface
• IGMP proxy
• IGMP snooping
• RIP
• UPnP
• VLAN support
• Supports ping co side external network (WAN ping respond)
• Support for SIP
• Support for RTSP
Firewall and Access Control
• IP-filters
• MAC-filter
• URL-Filter
• DMZ-zone
• The protection and ARP-DDoS-attacks
• Virtual servers
QoS
• Grouping interfaces
• Priority VLAN (802.1p)
USB-modem *
• Automatically connect to an available type of supported network (3G/2G)
• Enable / disable PIN-code verification, change PIN-code
USB-drive
• File Browser
• Print Server
• Access via SMB from accounts
• Built-in FTP-server
• Built-in DLNA-server
Torrent-client
• Built client Transmission
• Ability to download files on the USB-drive and with it
Configuration and Management
• Web-based interface for configuration and management of multiple languages
• Access via TELNET
• Upgrade the firmware of the router through the web-interface
• Automatic notification when a new software version
• Save and load configuration
• Support for remote logging
• Automatic synchronization of system time with a NTP-server and manually configure the date and time
• The Ping
Supported USB-modems **
• GSM-modems
  ◦ Alcatel X500
  ◦ D-Link DWM-152C1
  ◦ D-Link DWM-156C1
  ◦ Huawei E150
  ◦ Huawei E1550
  ◦ Huawei E156G
  ◦ Huawei E160G
  ◦ Huawei E169G
  ◦ Huawei E171
  ◦ Huawei E173 (Megafon)
  ◦ Huawei E220
  ◦ Huawei E352 (Megafon)
  ◦ Huawei E392 (3G-mode)
  ◦ ZTE MF112
  ◦ ZTE MF192
  ◦ ZTE MF626
  ◦ ZTE MF627
  ◦ ZTE MF652
  ◦ ZTE MF668
  ◦ ZTE MF752
• CDMA-modems
  ◦ Airplus MCD-650
  ◦ Airplus MCD-800
  ◦ AnyDATA ADU-300A
  ◦ AnyDATA ADU-500A
  ◦ AnyDATA ADU-510A
  ◦ Huawei EC306
  ◦ ZTE AC5710
  ◦ ZTE AC5730
Fiziksel Özellikler
Indicators
• POWER
• DSL
• INTERNET
• WLAN
• LAN 1-4
• WPS
• USB
Power
External Power Adapter DC 12V/1A
Buttons
• The Power Switch ON / OFF
• The RESET button to return to the factory defaults
• The button to turn on the wireless network and use the WPS function
Operating temperature
From 0 to 40 ° C
Storage temperature
-20 To 70 ° C
Humidity
From 5% to 95% non-condensing
* Options available only for GSM USB-modems.
** The manufacturer does not guarantee proper operation of the router with every modification of the USB-modems.
Ürünler | Destek  | Haberler  | Hakkında |
