DAS-4192-60Proje
POTS Splitter chassis for DAS-4192
Nereden Alınır
Tanımlama
POTS Splitter chassis for DAS-4192.
Genel Özellikler
Fiziksel Özellikler
Slots
4-slot SC
The physical parameters
Height
3U (13,3 cm)
Width
•  44 cm (without brackets) •  48.3 cm or 58.4 (with bracket)
Depth
27.4 cm
Weight
•  3.5 kg (chassis only)
•  11.5 (chassis with a full load)
Çözümler
Sipariş Bilgisi
Görseller
DAS-4192-60
Front view
İndir
Destek Merkezi
