DEVICE INTERFACES
+ 1 RJ-11 ADSL port
+ 4 RJ-45 10/100BASE-TX Fast Ethernet LAN switch ports with auto MDI/MDIX
+ Built-in 802.11g WLAN
+ 1 or 2 USB ports
WIRELESS LAN
+ IEEE 802.11g standard
+ Frequency range: 2.4 GHz to 2.497 GHz
+ Wireless speed: up to 54Mbps
+ 64/128-bit WEP data encryption
+ Multiple SSID
+ MAC-based ACL
+ WPA/WPA2 security with TKIP, AES support - WDS support
+ 802.11e WLAN QoS (WMM/WME)
ADSL STANDARDS
+ ADSL: Full-rate ANSI T1.413 Issue 2, ITU-T G.992.1 (G.dmt) Annex A, ITU-T G.992.2 (G.lite) Annex A, ITU-T G.994.1 (G.hs)
+ ADSL2: ITU-T G.992.3 (G.dmt.bis) Annex A/L/M, ITU-T G.992.4 (G.lite.bis) Annex A
+ ADSL2+: ITU-T G.992.5 Annex A/L/M
ADSL DATA RATES
+ G.dmt: 8Mbps downstream, 832Kbps upstream
+ G.lite: 1.5Mbps downstream, 512Kbps upstream
+ ADSL2: 12Mbps downstream, 1Mbps upstream
+ ADSL2+: 24Mbps downstream, 1Mbps upstream
ATM & PPP PROTOCOLS
+ Multiple protocol encapsulation over AAL5
+ Bridged and routed Ethernet encapsulation
+ Logical Link Control (LLC) encapsulation
+ VC-based multiplexing
+ ATM Forum UNI3.1/4.0 PVC
+ ATM Adaptation Layer Type 5 (AAL5)
+ ITU-T I.610 OAM F4/F5 loopback
+ ATM QoS (Traffc Shaping)
+ PPP over ATM
+ PPP over Ethernet
NETWORK PROTOCOLS AND FEATURES
+ IP Static Routing
+ RIP
+ NAT
+ Virtual Server, Port Forwarding
+ DHCP server/client/relay
+ DNS Relay, DDNS
+ IGMP proxy
+ SNTP
FIREWALL/ACCESS SECURITY
+ NAT frewall
+ MAC Filtering
+ Packet Filtering (IP/ICMP/TCP/UDP)
+ Stateful Packet Inspection (SPI)
+ Denial of Service (DoS) prevention
+ Intrusion Detection System and logging DMZ
VPN
+ Multiple IPSec/PPTP/L2TP pass-through
QOS
+ Traffc Prioritization/Classifcation
based on:
- Port
- 802.1p Priority Queues
- Application port
- User-defned (TCP/UDP/ICMP etc.)
+ 3 priority queues per PVC
+ PVC/VLAN port mapping
+ IGMP v.2 snooping
CONFIGURATION/MANAGEMENT
+ Quick Installation Wizard
+ Web-based GUI
+ Web-based/TFTP frmware upgrade, confguration up/download
+ SNMP v1, v2c, built-in MIB-I, MIB-II agent
+ TR-069 compliant
+ Factory reset button
Fiziksel ÖzelliklerDIAGNOSTIC LEDS
+ Power
+ DSL
+ WLAN
+ LAN (1-4)
+ Internet
+ USB 1 and 2
POWER
+ Power input: through 12VDC/1A
+ Power ON/OFF switch
DIMENSIONS
114mm x 31 mm x 191 mm
WEIGHT
350 grams
OPERATING TEMPERATURE
0˚ to 40˚ C (32˚ to 104˚ F)
STORAGE TEMPERATURE
-20˚ to 65˚ C (-4 ˚ to 149˚ F)
OPERATING HUMIDITY
5% to 95% non-condensing
Emission (EMC/EMI)
+ FCC Part 15 Class В
+ CE (EN55022/EN55024/EN300 328/EN301 489)
Safety
+ CSA
+ LVD
+ RoHS compliant
