DWL-3200APEOL EOS
802.11g İç Mekan Kablosuz Erişim Noktası
Nereden Alınır
Tanımlama
The D-Link AirPremier DWL-3200AP is a powerful and reliable wireless access point for business-class enterprise environments. Designed for indoor installation, this access point provides secure options for network administrators to deploy a highly manageable and extremely robust wireless network. This access point supports Power over Ethernet (PoE) and provides two high-gain antennas for optimal wireless coverage.
PoE Support. Enclosed in a plenum metal chassis, the DWL-3200AP adheres to strict fire codes and ensures complete safety. For advanced installations, this high-speed access point has an integrated 802.3af Power over Ethernet (PoE) support to allow installation in areas where power outlets are not readily available.
Up to 108Mbps Wireless Speed. The DWL-3200AP delivers extremely reliable wireless performance with standard 802.11g wireless throughput rates of up to 54Mbps. It has the added capability of reaching maximum wireless signal rates of up to 108Mbps (Turbo mode) powered by D-Link 108G technology. At the same t ime, the DWL-3200AP remains fully compatible with the IEEE 802.11b and 802.11g standards.
Advanced Wireless Security. Since wireless security remains a strong concern among businesses, the DWL-3200AP provides the latest wireless security technologies by supporting both WPA-Enterprise and WPA2-Enterprise to ensure complete network protection. In addition, the DWL-3200AP currently comes 802.11i-ready to fully support industrial grade wireless security.
WDS (Wireless Distribution System) Support. To maximize total return on investment,  the DWL-3200AP can be configured to operate as an access point (AP mode), a point-to-point bridge or a point-to-multipoint bridge (WDS mode). In the WDS/Bridge mode, the DWL-3200AP communicates only with wireless bridges, without allowing for wireless clients or stations to access them.
Increased Network Flexibility and Efficiency. The DWL-3200AP supports multiple SSIDs, allowing you to separate applications based on security and performance requirements. You can enable
encryption and authentication on one SSID to protect private applications and no security on another SSID to maximize open connectivity for public usage. Multiple SSIDs means you can mix and match the broadcasting of SSIDs. For public Internet access applications, you can broadcast the SSID to enable user radio cards to automatically find available access points. For private applications, you can disable SSID broadcast to prevent intruders from identifying your network. You can set the number of users that can associate via a particular SSID to control usage of  particular applications. This can help provide a somewhat limited form of bandwidth control for particular applications.
Cost Saving and Mobile Applications. By supporting multiple SSIDs, the DWL-3200AP allows you to logically divide your access point into several virtual access points all within a single hardware platform. Rather than having two separate WLANs, you can deploy one access point to support more than one application, such as public Internet access and internal network control to increase flexibility and keep costs down.
Advanced Network Management. Network administrators can manage all the DWL-3200AP's settings via its web-based configuration utility or with Telnet. For advanced network management, the administrators can use D-Link's AP Manager or D-View SNMP management module to configure and manage multiple access points from a single location. In addition to a streamlined management process, network administrators can also verify and conduct regular maintenance checks without wasting resources by sending personnel out to physically verify proper operation.
Genel Özellikler
Standartları
• IEEE 802.11b
• IEEE 802.11g
• IEEE 802.3
• IEEE 802.3u
• IEEE 802.3af
Veri aktarım hızı *
802.11g için:
• 54, 48, 36, 24, 18, 12, 9 ve 6 Mbps
802.11b için:
• 11, 5.5, 2 ve 1 Mbps
* Teorik kablosuz sinyal oranı. Gerçek veri akışı çevre koşullarına bağlı olarak değişir.
Frekans bandı
2400-2483,5 MHz
Anten
İki çıkarılabilir 5dBi ters SMA konektörü ile ayrılmış anten dipol
Modülasyon
• 802.11b için:
DSSS:
DBPSK @ 1 Mbps
DQPSK @ 2 Mbps
CCK @ 5,5 Mbps ve 11 Mbps
 • 802.11g için:
OFDM:
BPSK @ 6 Mbps ve 9 Mbps
QPSK @ 12 Mbps ve 18 Mbps
16QAM @ 24 Mbps ve 36 Mbps
64QAM @ 48 Mbps ve 54 Mbps
Verici güç
 • 802.11b için:
1mW (0dBm)
5mW (7dBm)
10mW (10dBm)
20mW (13dBm)
30mW (15dBm)
50mW (17dBm)
100mW (20dBm))
 •802.11g için:
1mW (0dBm)
5mW (7dBm)
10mW (10dBm)
20mW (13dBm)
30mW (15dBm)
63mW (18dBm)
100mW (20dBm)
Alıcı Hassasiyeti
•802.11b için:
1 Mbps:-94dBm
2 Mbps:-90dBm
5.5 Mbps:-89dBm
11 Mbps:-85dBm
• 802.11g için:
1 Mbps:-94dBm
2 Mbps:-90dBm
5.5 Mbps:-89dBm
6 Mbps:-90dBm
9 Mbps:-84dBm
11 Mbps:-85dBm
12 Mbps:-82dBm
18 Mbps:-80dBm
24 Mbps:-77dBm
36 Mbps:-73dBm
48 Mbps:-72dBm
54 Mbps:-72dBm
Yapılandırma ve yönetme
• Web tabanlı yönetim arabirimi: Internet Explorer v.6 veya sonrası; Netscape Navigator v.7 veya diğer Java destekli tarayıcılar
• Telnet
• Yönetici erişim noktası (AP Yöneticisi)
• SNMP v.3
Çalışma modları
• Access Point (Erişim Noktası)
• Köprü Point (PtP) Noktasına
• Köprü Noktadan (PtMP) çoklu için
Güvenlik
• Veri Şifreleme 64 / 128/152-bit WEP
• Filtre MAC adresi
• WPA/WPA2 EAP
• WPA/WPA2 PSK
• 802.1x Kimlik Denetimi
• AES
• 802.11i hazır
• / Disable SSID Broadcast etkinleştirin
• 802.1Q Çoklu SSID (en fazla 8)
Uzaklıkta *
802.11g (dipol antenlerin tam güç 5dBi aralıklı ile):
• Kapalı:
30m @ 54 Mbps
34m @ 48 Mbps
39 milyon @ 36 Mbps
47m @ 24 Mbps
56m @ 18 Mbps
66m @ 12 Mbps
79m @ 9 Mbps
99m @ 6 Mbps
• Dış: En fazla 400 m
112m @ 54 Mbps
250 @ 18 Mbps
500m @ 6 Mbps
* Ailesi birçok çevresel faktörlerden etkilenebilir
Fiziksel Özellikler
Göstergeler
Güç (Power)
LAN
802.11b / g
Çalışma gerilimi
PoE için 48 VDC + / -10%
Güç tüketimi
6.24 watt (130mA) (max.)
Boyutlar
277,7 x 155 x 45 mm
Çalışma sıcaklığı
40 ° 0 ° C
Depolama sıcaklığı
65 ° -40 ° C
Nem
Çalışma: 10% 90% yoğunlaşmamış
Depolama:% 5 ila% 95 yoğuşmasız
Sertifikalar
FCC Sınıf B
CE
• Wi-Fi
Çözümler
Sipariş Bilgisi
Görseller
DWL-3200AP/B1
Front view
İndir
Destek Merkezi
