DAP-1620EOL
Wireless Dual Band Repeater АС1200
Nereden Alınır
Tanımlama
Tanımlama: Easy solution for extending the coverage area of Wi-Fi Access to an existing wireless network where the signal of the access point or router is weak or non-existent 2 frequency range 5 GHz for Wi-Fi networks of new generation 802.11 ac 2.4 GHz for wireless devices previous standards Modern wireless standard 802.11 ac The General speed wireless connection up to 1200 Mbit/S1 The most effective installation The signal strength indicator Wi-Fi, allowing you to choose a suitable location for setting point To expand the coverage area of the wireless network? Easy! Wireless dual band repeater DAP АС1200-1620 is a portable device that allows you to increase the coverage area of an existing wireless network. DAP-1620 can be placed anywhere in Your house where the signal from the router or access point is too weak or non-existent. Get rid of dead spots Wi-Fi and you can work wherever You want: Installation in any convenient location by a simple press of a button DAP-1620 operates on the principle of Plug-and-Play and configured in minutes, not demanding serious knowledge of network technologies. To expand the coverage area, simply connect the DAP-1620 to an electrical outlet, press the WPS button on the router and then to the repeater. To configure mobile device running iOS or Android is available free app D-Link QRS Mobile. Improve your wireless network With the repeater DAP-1620 You can cost-effective way to upgrade an existing home network, operating only in the 2.4 GHz band, and to organize the work at speeds of a new generation of Wi-Fi to the less-congested 5 GHz frequency range. Create more opportunities to connect their mobile, entertainment and “smart" devices – smartphones, tablets, laptops, e-books, game consoles and TVs with the Smart TV function. 1 Maximum wireless data transfer defined by the specification of IEEE 802.11 ac and 802.11 n. The data transfer speed may vary considerably from speed wireless connection. The conditions in which operates the network, as well as environmental factors, including volume of network traffic, building materials and construction, and network overhead can lower actual data throughput rate. On the range of your wireless network factors may adversely affect the environment.
Genel Özellikler
Fiziksel Özellikler
Çözümler
Sipariş Bilgisi
Görseller
DAP-1620
View from the right
View from the right
Front view
İndir
Destek Merkezi
