DWL-8710APEOL EOS
Outdoor Wireless Dual Band unified access point PoE
Tanımlama
Outdoor Wireless Dual Band unified access point DWL-8710AP with PoE is designed for use in enterprise networks that require data transfer for small and medium distances.
Designed for outdoor use, the AP DWL-8710AP is made in weatherproof housing that complies with IP67 and protects against dust and moisture.
2 bandwidth
5 GHz WDS-organization of the compounds, 2.4 GHz to create a wireless local area network
Modern wireless standard 802.11ac
Total wireless speed - up to 1200 Mbit / s 1
Ability to use outdoors
Wide operating temperature range - from -40 ° C to 70 ° C
Protected housing
Metal housing with a protection class of dust and moisture IP67
The maximum effective installation
Signal level Wi-Fi, which allows to choose the optimal location for the point
Centralized management
Working in a controlled access point with wireless switches and controllers D-Link
High-speed wireless connection
Access Point DWL-8710AP allows you to create a managed wireless network with the best coverage in the 2.4 GHz band (802.11b, 802.11g, 802.11n), and 5 GHz (802.11a, 802.11n, 802.11ac). DWL-8710AP delivers reliable wireless connectivity at speeds up to 300 Mbit / s in the 2.4 GHz band and up to 867 Mbit / s in the range of 5 GHz1.
The access point supports MIMO 2x2 and is equipped with two detachable omni-directional antennas with a gain of 7 dBi for 5 GHz frequency band and two detachable omnidirectional antennas 5 dBi for 2.4 GHz. This solution enables stable operation of WDS-connections on medium distances in the 5 GHz band and thus arrange local access to a wireless network in the 2.4GHz band.
Enterprise-class Security
In the stand-alone access point wireless network protection and control of connected clients implemented using encryption protocols WEP, WPA / WPA2 (Personal / Enterprise), authentication, 802.1X, filtering by MAC-address of the wireless client isolation mechanism, and the possibility of disabling the broadcast SSID. In the controlled access point expands the functional safety through the use of adaptive features of the portal (Captive Portal) and technology WIDS to detect rogue access points / clients and prevent unauthorized access.
A wide range of control functions
DWL-8710AP supports Multiple SSID with up to 8 virtual wireless networks and allows you to segment network traffic by using different VLAN. The device also supports 802.1d Spanning Tree protocol for fault tolerance WDS-connections, load balancing, and WMM (QoS).
Centralized management of the wireless network
When working with the unified switches or controllers D-Link Access Point DWL-8710AP supports centralized management that makes it easy to configure and manage a large number of APs. After the discovery of the switch or access point controller, the administrator can specify a single configuration for all of TD immediately instead configure each AP individually. In addition to that provided centralized management of radio frequency resources and security settings, which in turn allows the administrator to pre-identify potential weaknesses and vulnerabilities in the network.
Automatic adjustment of the frequency plan and the power of 2
When using the controller to control multiple access point supports automatic adjustment of the frequency plan and power access points, allowing greater fault tolerance and organize the smooth operation of the network. This functionality provides the switching points of access to the less loaded channel and automatically adjusts the radiation power to reduce or eliminate the interference areas with weak signal.
Quality of Service
DWL-8710AP supports 802.1p Quality of Service (QoS) to increase throughput and productivity when transferring delay-sensitive traffic, for example, VoIP or video streaming. To better manage bandwidth wireless network function is supported by WMM, allows you to assign different types of traffic required levels of priority.
Load Balancing
In addition, the access point DWL-8710AP supports load balancing. If multiple TD-enabled load balancing are in close proximity to each other, the TD, whose resources are fully utilized, will reject new connection requests. Instead, the connection request will be accepted by the neighboring access point. Thus, by using this feature, the load on the access points will be distributed evenly.
1 Maximum wireless signal rate derived from the specifications of standards IEEE 802.11ac. Actual data throughput will vary. The conditions under which the network operates, as well as environmental factors, including volume of network traffic, building materials and construction, and network overhead, lower actual data throughput rate. In the range of the wireless network can be affected by environmental factors.
2 This function is available when using a unified access point, together with standardized wireless switches / controllers D-Link.
