DWL-6700APEOL EOS
Dual Band Outdoor Wireless Unified Access Point
Tanımlama
Outdoor Wireless Dual Band unified access point D-Link DWL-6700AP is designed for use in enterprise networks that require data transfer for small and medium distances.
2 bandwidth
5 GHz WDS-organization of the compounds, 2.4 GHz to create a wireless local area network
Modern wireless standard 802.11n
High-speed connections - up to 300 Mbit / s
Ability to use outdoors
Wide operating temperature range - from -30 ° C to 50 ° C
Protected housing
Plastic housing with a protection class of dust and moisture IP55
The maximum effective installation
Signal level Wi-Fi, which allows to choose the optimal location for the access point
Centralized management
Working in a controlled access point with wireless switches and controllers D-Link
Flexible access to a wireless network
The access point supports MIMO 2x2 and is equipped with two built-in directional antennas with a gain of 8 dBi for 5 GHz frequency band and two omnidirectional antennas with a gain of 3 dBi for 2.4 GHz. This solution enables stable operation of WDS-connections on medium distances in the 5 GHz band and thus arrange local access to a wireless network in the 2.4GHz band.
Centralized management of the wireless network
When working with the unified switches or controllers D-Link Access Point DWL-6700AP supports centralized management that makes it easy to configure and manage a large number of APs. After the discovery of the switch or access point controller, the administrator can specify a single configuration for all of TD immediately instead configure each AP individually. In addition to that provided centralized management of radio frequency resources and security settings, which in turn allows the administrator to pre-identify potential weaknesses and vulnerabilities in the network.
LED signal strength Wi-Fi and a remote reset button
This access point is equipped with an indicator signal Wi-Fi, which allows to monitor the signal WDS-connections for the 5 GHz frequency range. Thus, the administrator can easily determine the optimum location of the AT required to obtain the maximum signal when receiving from the AT on the opposite side, even if two access points are located at a distance of 2 km from each other. In addition to the main button reset to factory settings, located directly on the access point to the factory settings can be performed remotely using a special button on PoE-injector supplied with the AP.
Quality of Service
DWL-6700AP supports 802.1p Quality of Service (QoS) to increase throughput and productivity when transferring delay-sensitive traffic, for example, VoIP and video streaming. Since DWL-6700AP supports WMM, in the case of a high network load will primarily handle the traffic with the highest priority. In addition, the access point DWL-6700AP supports load balancing. If multiple TD-enabled load balancing are in close proximity to each other, the TD, whose resources are fully utilized, will reject new connection requests. Instead, the connection request will be accepted by the neighboring access point. Thus, by using this feature, the load on the access points will be distributed evenly.
