DAP-1360U
Wireless N300 Access Point & Router
Tanımlama
Wireless Interface
Using DAP-1360U, you are able to quickly create a wireless network and let your relatives or employees connect to it virtually anywhere (within the operational range of your wireless network). The access point can operate as a base station for connecting wireless devices of the standards 802.11b, 802.11g, and 802.11n (at the rate up to 300Mbps).
Secure Wireless Connection
The device supports multiple functions for the wireless interface: several security standards (WEP, WPA/WPA2), MAC address filtering, different operation modes (access point, router, client), WPS, WDS, WMM.
In addition, the device is equipped with a button for switching the Wi-Fi network off/on. If needed, for example, when you leave home, you can easily switch the access point’s WLAN by pressing the button, and devices connected to the LAN ports of the access point will stay online.
Smart adjustment of Wi-Fi clients is useful for networks based on several D-Link access points or routers – when the smart adjustment function is configured on each of them, a client always connects to the access point (router) with the highest signal level.
Support of guest Wi-Fi network in the router mode allows you to create a separate wireless network with individual security settings and maximum rate limitation. Devices connected to the guest network will be able to access the Internet, but will be isolated from the devices and resources of the access point's LAN.
Access Point Mode
You are able to use DAP-1360U switched to the access point mode to create a wireless network or to connect to a wired router.
Router Mode
You are able to connect DAP-1360U switched to the router mode to a cable or DSL modem or to a private Ethernet line and use a high-speed Internet connection to successfully fulfill a wide range of professional tasks.
“Client” Function
The “client” function in the access point mode allows using DAP-1360U as a wireless client and a wireless repeater, in the router mode as a WISP repeater.
Security
In the router mode, the DAP-1360U device includes a built-in firewall. The advanced security functions minimize threats of hacker attacks, prevent unwanted intrusions to your network, and block access to unwanted websites for users of your LAN.
Easy configuration and update
You can configure the settings of the DAP-1360U device via the user-friendly web-based interface (the interface is available in two languages – in Russian and in English).
The configuration wizard allows you to connect DAP-1360U to a wired or wireless ISP (when switched to the router mode) in several simple steps or quickly set needed parameters for operation as an access point, repeater, or client (when switched to the access point mode).
Also DAP-1360U supports configuration and management via mobile application for Android smartphones.
You can simply update the firmware: the access point itself finds approved firmware on D-Link update server and notifies when ready to install it.
Genel Özellikler
				 Hardware
				 Processor
				 • RTL8196D (620MHz)
				 RAM
				 • 32MB, SDRAM
				 Flash
				 • 4MB, SPI
				 Interfaces
				 • 10/100BASE-TX WAN port
				• 4 10/100BASE-TX LAN ports
				 LEDs
				 • POWER
				• WLAN
				• WPS
				• INTERNET
				• 4 LAN LEDs
				 Buttons
				 • ON/OFF button to power on/power off
				• RESET button to restore factory default settings
				• WPS button to set up wireless connection and enable/disable wireless network
				 Antenna
				 • Two detachable omnidirectional antennas (5dBi gain)
				• RP-SMA connector
				 Power connector
				 • Power input connector (DC)
				 Software
				 WAN connection types
				 • PPPoE
				• Static IPv4 / Dynamic IPv4
				• PPPoE + Static IP (PPPoE Dual Access)
				• PPPoE + Dynamic IP (PPPoE Dual Access)
				• PPTP/L2TP
				• PPTP/L2TP + Static IP
				• PPTP/L2TP + Dynamic IP
				 Network functions
				 • DHCP server/relay
				• Automatic obtainment of LAN IP address (for access point/repeater/client/WDS modes)
				• DNS relay
				• Dynamic DNS
				• Static IP routing
				• IGMP Proxy
				• RIP
				• Support of UPnP IGD
				• Support of VLAN
				• WAN ping respond
				• Support of SIP ALG
				• Support of RTSP
				• Autonegotiation of speed, duplex mode, and flow control/Manual speed and duplex mode setup for each Ethernet port
				• Setup of maximum TX rate for each port of the access point
				 Firewall functions
				• IP filter
				• MAC filter
				• URL filter
				• DMZ
				• Prevention of ARP and DDoS attacks
				• Virtual servers
				 VPN
				 Management
				 • Local and remote access to settings through TELNET/WEB (HTTP/HTTPS)
				• Bilingual web-based interface for configuration and management (Russian/English)
				• Support of D-Link Assistant application for Android smartphones
				• Support of logging to remote host
				• Ping utility
				• Traceroute utility
				 Wireless Module Parameters
				 Standards
				 • IEEE 802.11b/g/n
				 Frequency range
				 • 2400 ~ 2483.5MHz
				 Wireless connection security
				 • WEP
				• МАС filter
				• WPS (PBC/PIN)
				 Advanced functions
				 • Support of client mode
				• WMM (Wi-Fi QoS)
				• Information on connected Wi-Fi clients
				• Advanced settings
				• Smart adjustment of Wi-Fi clients
				• Guest Wi-Fi / support of MBSSID
				• Rate limitation for wireless network/separate MAC addresses
				• Periodic scan of channels, automatic switch to least loaded channel
				• WDS
				• Autonegotiation of channel bandwidth in accordance with environment conditions (20/40 Coexistence)
				 Wireless connection rate
				 • IEEE 802.11b: 1, 2, 5.5, and 11Mbps
				• IEEE 802.11g: 6, 9, 12, 18, 24, 36, 48, and 54Mbps
				• IEEE 802.11n: from 6.5 to 300Mbps (from MCS0 to MCS15)
				 Transmitter output power
				 • 802.11b (typical at room temperature 25 °C)
				15dBm (+/-1.5dB) at 1, 2, 5.5, 11Mbps
				• 802.11g (typical at room temperature 25 °C)
				15dBm (+/-1.5dB) at 6, 9, 12, 18, 24, 36, 48, 54Mbps
				• 802.11n (typical at room temperature 25 °C)
				HT20
				15dBm (+/-1.5dB) at MCS0/1/2/3/4/5/6/8/9/10/11/12/13/14
				14dBm (+/-1.5dB) at MCS7/15
				HT40
				 Receiver sensitivity
				 • 802.11b (typical at PER = 8% at room temperature 25 °C)
				-82dBm at 1Mbps
				-80dBm at 2Mbps
				-78dBm at 5.5Mbps
				-76dBm at 11Mbps
				• 802.11g (typical at PER = 10% at room temperature 25 °C)
				-85dBm at 6Mbps
				-84dBm at 9Mbps
				-82dBm at 12Mbps
				-80dBm at 18Mbps
				-77dBm at 24Mbps
				-73dBm at 36Mbps
				-69dBm at 48Mbps
				-68dBm at 54Mbps
				• 802.11n (typical at PER = 10% at room temperature 25 °C)
				HT20
				-82dBm at MCS0/8
				-79dBm at MCS1/9
				-77dBm at MCS2/10
				-74dBm at MCS3/11
				-70dBm at MCS4/12
				-66dBm at MCS5/13
				-65dBm at MCS6/14
				-64dBm at MCS7/15
				HT40
				-79dBm at MCS0/8
				-76dBm at MCS1/9
				-74dBm at MCS2/10
				-71dBm at MCS3/11
				-67dBm at MCS4/12
				-63dBm at MCS5/13
				-62dBm at MCS6/14
				-61dBm at MCS7/15
				 Modulation schemes
				• 802.11g: BPSK, QPSK, 16QAM, 64QAM with OFDM
				• 802.11n: BPSK, QPSK, 16QAM, 64QAM with OFDM
				 Compatible equipment and accessories
				 Antennas
				 • ANT24-0800
				• ANT24-0801
				• ANT24-0802
				• ANT24-0802C
				• ANT24-1200
				• ANT24-1201
				• ANT24-1202
				• ANT24-1400
				• ANT24-1800
				• ANT24-2100
				• ANT70-0800
				• ANT70-1000
				• ANT70-1400N
				• ANT70-1800
				 Extension cable
				 • ANT24-CB03N (only with external antennas)
				• ANT24-CB06N (only with external antennas)
				• ANT24-CB09N (only with external antennas)
				 Lighting surge protector
				 • ANT70-SP (only with external antennas)
				• ANT-SP (only with external antennas)
				 Physical Parameters
				 Dimensions
				 • 174 x 115 x 30 mm (7 x 4.5 x 1.2 in)
				 Weight
				 • 248 g (0.55 lb)
				 Operating Environment
				 Power
				 • Output: 12V DC, 0.5A
				 Temperature
				 • Operating: from 0 to 40 °C
				• Storage: from -20 to 65 °C
				 Humidity
				 • Operating: from 10% to 90% (non-condensing)
				• Storage: from 5% to 95% (non-condensing)
				 Delivery Package
				 • Access point DAP-1360U
				• Power adapter DC 12V/0.5A
				• Ethernet cable
				• Two detachable antennas
Çözümler
Sipariş Bilgisi
DAP-1360 Wireless N300 Access Point & Router
