DWA-160/C1EOL EOS
Dual-band (2,4/5GHz) 802.11n kablosuz USB adaptör, 300 Mbit/s
Tanımlama
	Wireless dual-band (2.4/5 GHz) wireless USB adapter DWA-160 enables a reliable wireless connection to a public wireless network ("hotspot") or dvuhdiapazonnomu router, which can be used for streaming high-definition video (HD). USB adapter DWA-160 enables you to connect your computer to a high-speed wireless network and provides excellent signal reception. Once connected, you can get access to high-speed Internet connection, as well as the total secure access to your photos, files, music, video, printers, and storage.
	Use two frequency bands
	USB adapter DWA-160 supports dual-band 2.4 Ghz range this can be used to check e-mail and access the Internet through a wireless network in the 5 Ghz frequency range it is possible to transfer an HD streaming video and other media content.
	Increased speed and expanded the range of network
	Dual band USB adapter DWA-160 Xtreme N provides a connection to the wireless network at a faster speed and at a greater distance than the previous 802.11 standards adapters. This ensures quick and reliable connection anywhere in your home.
	Easy installation and use
	Installation Wizard provides step-by-step instructions that you can use to quickly and easily connect to a wireless network, even in the absence of experience with networks. Due to its high performance, reception and security, this adapter is the best choice for wireless connection of desktop computers.
