Ürün Özellikleri:
Outdoor Wireless 802.11n Access Point, up to 300 Mbit / s |
Genel Özellikler:
Fiziksel Özellikler
Device Interfaces
• 802.11n/g/b
• 2-port Ethernet 10/100 Mbit / s (one port supports PoE)
• The Reset button
• Connector for the ground wire 7
Indicators
• Power
• LAN
• Wireless Transmit Power 8
Antenna
Sector antenna with a gain of 10 dBi
Standards
• IEEE 802.11b/g/n
• IEEE 802.3
• IEEE 802.3u
Frequency band
• 802.11b: from 2.4 GHz to 2.497 GHz
• 802.11g: from 2.4 GHz to 2.4835 GHz
• 802.11n: from 2.4 GHz to 2.4835 GHz
Wireless speed
• 802.11b: 11, 5.5, 2, 1 Mbit / s
• 802.11g: 54, 48, 36, 24, 18, 12, 9, 6 Mbit / s
• 802.11n:
Unit: Mbit / s
The output power of the transmitter
• IEEE 802.11b:
28 ± 2 dBm at 1, 2, 5,5, 11 Mbit / s
• IEEE 802.11g:
26 ± 2 dBm at 6-36 Mbit / s
24 ± 2 dBm at 48 Mbit / s
23 ± 2 dBm at 54 Mbit / s
• IEEE 802.11n:
2.4 GGts/HT-20
26 ± 2 dBm at MCS0 / 8,1 / 9,2 / 10,3 / 11
25 ± 2 dBm at MCS4/12
24 ± 2 dBm at MCS5/13
23 ± 2 dBm at MCS6/14
22 ± 2 dBm at MCS7/15
2.4 GGts/HT-40
25 ± 2 dBm at MCS0 / 8,1 / 9,2 / 10
25 ± 2 dBm at MCS3/11
24 ± 2 dBm at MCS4/12
23 ± 2 dBm at MCS5/13
22 ± 2 dBm at MCS6/14
21 ± 2 dBm at MCS7/15
Receiver Sensitivity
• IEEE 802.11b:
-96 ± 2 dBm at 1 Mbit / s
-94 ± 2 dBm at 2 Mbit / s
-91 ± 2 dBm at 5.5 Mbit / s
-88 ± 2 dBm at 11 Mbit / s
• IEEE 802.11g:
-90 ± 2 dBm at 6 Mbit / s
-89 ± 2 dBm at 9 Mbits / s
-88 ± 2 dBm at 12 Mbit / s
-86 ± 2 dBm at 18 Mbit / s
-84 ± 2 dBm at 24 Mbit / s
-80 ± 2 dBm at 36 Mbit / s
-76 ± 2 dBm at 48 Mbit / s
-74 ± 2 dBm at 54 Mbit / s
• IEEE 802.11n:
2.4 GGts/HT-20
-90 ± 2 dBm at MCS0 / 8
-88 ± 2 dBm at MCS1 / 9
-86 ± 2 dBm at MCS2/10
-82 ± 2 dBm at MCS3/11
-78 ± 2 dBm at MCS4/12
-75 ± 2 dBm at MCS5/13
-74 ± 2 dBm at MCS6/14
-72 ± 2 dBm at MCS7/15
2.4 GGts/HT-40
-85 ± 2 dBm at MCS1 / 9
-83 ± 2 dBm at MCS2/10
-80 ± 2 dBm at MCS3/11
-76 ± 2 dBm at MCS4/12
-72 ± 2 dBm at MCS5/13
-71 ± 2 dBm at MCS6/14
-69 ± 2 dBm at MCS7/15
Modes of operation
• TD
• WDS
• WDS access point
• Wireless client
• Repeater
• WISP Repeater
• WISP Client Router
Network control
• Web-interface
• HTTP - Secure HTTP (HTTPS)
• SNMP v1, v2c, v3
Safety
• WPA2-Personal/Enterprise
• WPA-Personal/Enterprise
• 64/128-bit WEP
• 802.1X
SSID / VLAN
Supports up to 8 SSID / VLAN
Dimensions
118 x 56 x 195 mm
Weight
305 g
Operating voltage
48 VDC ± 10% for PoE
Max. power consumption
13.5 W
Temperature
• Operating: -20 to 60 C
• Storage: -20 to 85 C
Humidity
• Operating: 10% to 90% (non-condensing)
• Storage: 5% to 95% (non-condensing)
ESD-protection
15 kV
Certifications
• CE
• FCC
6 It is impossible to organize a WDS access point series AirPremierN.
7 The ground wire is not included in the package. It is recommended to use a ground wire gauge 16-18 AWG for normal outdoor use.
8 Display the signal strength is only supported as a wireless client, repeater, WDS and WISP.
Destek Merkezi
