DWA-182EOL EOS
Dual-Band Wireless 802.11a/g/n/ac 2.4/5GGts USB-adapter AC1200
Nereden Alınır
Tanımlama
Wireless USB-Adapter DWA-182 standard 802.11ac provides enhanced data rate wireless network. Simply insert the adapter into a free USB-port and connect to a secure wireless network with Internet access. Once connected to the network via an adapter DWA-182, you can view web-pages, and chat with friends online. Dual-band adapter supports 2.4 GHz (300 Mbit / s 1 ) or 5 GHz (up to 867 Mbit / s 1 ). Furthermore, the ability of 5 GHz to reduce interference from outside Wi-Fi networks, bandwidth, and hence increase the speed of data streaming, gaming and VoIP-telephony.
The bandwidth without interference
The use of technology in dual band adapter DWA-182 provides interference-free bandwidth. Check your mail and visit Web-sites can be in the 2.4 GHz band, and play online games, make Internet phone calls, and view streaming HD-video - in this interference-free 5 GHz band.
Easy setup with one click
Wireless Protected Setup (WPS) allows you to quickly and easily establish a secure connection to the wireless network.The latest encryption technology ensures the safety of data transferred in the network and prevents unauthorized access to them. To connect the touch of a button.
Compatible with all wireless devices
Adapter DWA-182 supports the latest standard 802.11ac, which provides backward compatibility with all existing wireless devices. Therefore, there is no need to replace the old or the use of additional devices.
USB 3.0 for maximum data transfer rates *
Adapter DWA-182 also supports Hi-Speed ​​USB 3.0. When connected to a USB 3.0 compatible device at 5 GHz DWA-182 automatically switches to USB 3.0, providing maximum data rate using all the advantages of standard Wireless AC.
802.11ac standard
802.11ac - a new wireless standard that provides a high data rate in the 5 GHz band. Because of this, guaranteed no distortions or delays when transferring HD-video streaming, video calling, VoIP-telephony work or play. 802.11ac standard provides data transmission without delay and at a high speed. In addition, the DWA-182 adapter is backward compatible with all existing wireless 802.11n/g/b devices.
* DWA-182 hardware version A1 only supports USB 2.0
1 Maximum wireless signal rate derived from standard specifications IEEE 802.11ac (draft) and 802.11n. Company D-Link does not guarantee compatibility with any future standards or interoperability of 802.11ac (draft) devices from other manufacturers. The data rate may differ significantly from the speed of wireless connections. The conditions under which the network operates, as well as environmental factors, including volume of network traffic, building materials and construction, and network overhead, lower actual throughput. On the range of a wireless network can be affected by environmental factors. Wireless transmission speeds up to 867 Mbit / s is achieved when connecting to other 802.11ac devices. Data rate may also be limited by interface devices (less than 480 Mbit / s interface USB 2.0). Your computer must meet the recommended system requirements for Microsoft.
Genel Özellikler
Fiziksel Özellikler
Indicator
Connection Status
Safety
• Wi-Fi Protected Access (WPA ™ and WPA2 ™)
• Wi-Fi Protected Setup - PIN and PBC
Standards
• IEEE 802.11ac (draft)
• IEEE 802.11n
• IEEE 802.11g
• EEE 802.11b
• EEE 802.11a
Antenna Type
Flush antenna
Wireless speed
• IEEE 802.11a: 54, 48, 36, 24, 18, 12, 9 and 6 Mbit / s
• IEEE 802.11b: 11, 5.5, 2 and 1 Mbit / s
• IEEE 802.11g: 54, 48, 36, 24, 18, 12, 9 and 6 Mbit / s
• IEEE 802.11n:
MCS GI = 800ns GI = 400ns
  20MHz 40MHz 20MHz 40MHz
0 6.5 13.5 7.2 15
1 13 27 14.4 30
2 19.5 40.5 21.7 45
3 26 54 28.9 60
4 39 81 43.3 90
5 52 108 57.8 120
6 58.5 121.5 55.0 135
7 65 135 72.2 150
8 13 27 14,444 30
9 26 54 28.889 60
10 39 81 43.333 90
11 52 108 57.778 120
12 78 162 86.667 180
13 104 216 115.556 240
14 117 243 130,000 170
15 130 270 144.444 300
•  IEEE 802.11ac:
0 58.5 65.0
1 117.0 130.0
2 175.5 195.0
3 234.0 260.0
4 351.0 390.0
5 468.0 520.0
6 526.5 585.0
7 585.0 650.0
8 702.0 780.0
9 780.0 866.7
The output power of the transmitter
• IEEE 802.11a:
  18 dBm at 6 Mbit / s
  15 dBm at 54 Mbit / s
• IEEE 802.11b:
  19 dBm at 1 Mbit / s
  17 dBm at 11 Mbit / s
• IEEE 802.11g:
• IEEE 802.11n:
2.4 GGts/HT-20 :
18 dBm at MCS0
15 dBm at MCS7
2.4 GGts/HT-40:
18 dBm at MCS0
15 dBm at MCS7
5 GGts/HT-20:
18 dBm at MCS0
15 dBm at MCS7
5 GGts/HT-40:
18 dBm at MCS0
15 dBm at MCS7
• IEEE 802.11ac:
18 dBm at at MCS0
15 dBm at at MCS7
13 dBm at at MCS8
12 dBm at at MCS9
Receiver Sensitivity
• IEEE 802.11a:
  -65 DBm at 54 Mbit / s
  -66 DBm at 48 Mbit / s
  -70 DBm at 36 Mbit / s
  -74 DBm at 24 Mbit / s
  -77 DBm at 18 Mbit / s
  -79 DBm at 12 Mbit / s
  -81 DBm at 9 Mbits / s
  -82 DBm at 6 Mbit / s
• IEEE 802.11b:
  -82 DBm at 11 Mbit / s
  -85 DBm at 5.5 Mbit / s
  -87 DBm at 2 Mbit / s
  -87 DBm at 1 Mbit / s
• IEEE 802.11g:
• IEEE 802.11n:
2.4 GGts/HT-20
-82 DBm at MCS8
-79 DBm at MCS9
-77 DBm at MCS10
-74 DBm at MCS11
-70 DBm at MCS12
-66 DBm at MCS13
-65 DBm at MCS14
-64 DBm at MCS15
2.4 GGts/HT-40:
-79 DBm at MCS8
-76 DBm at MCS9
-74 DBm at MCS10
-74 DBm at MCS11
-67 DBm at MCS12
-63 DBm at MCS13
-62 DBm at MCS14
-61 DBm at MCS15
5 GGts/HT-20
-82 DBm at MCS8
-79 DBm at MCS9
-77 DBm at MCS10
-74 DBm at MCS11
-70 DBm at MCS12
-66 DBm at MCS13
-65 DBm at MCS14
-64 DBm at MCS15
-59 DBm at MCS8
5 GGts/HT-40
-79 DBm at MCS8
-76 DBm at MCS9
-74 DBm at MCS10
-74 DBm at MCS11
-67 DBm at MCS12
-63 DBm at MCS13
-62 DBm at MCS14
-61 DBm at MCS15
-56 DBm at MCS8
-54 DBm at MCS9
• IEEE 802.11ac:
5 GGts/HT-80
-76 DBm at MCS0
-73 DBm at MCS1
-71 DBm at MCS2
-68 DBm at MCS3
-64 DBm at MCS4
-60 DBm at MCS5
-59 DBm at MCS6
-58 DBm at MCS7
-53 DBm at MCS8
-51 DBm at MCS9
5 GGts/VHT-40:
-56 DBm at MCS8
-54 DBm at MCS9
5 GGts/VHT-20:
-57 DBm at MCS8
Requirements
• Operating System: Windows 8/7/Vista/XP SP3
• Compatible browsers: Internet Explorer ® v7 or higher, Mozilla ® Firefox ® v3.0 or higher
• Interface:
  - USB-port
  - Supports standard USB 3.0 (optional) *
Fiziksel Özellikler
Measurements
96,7 x 28,6 x 11,5 mm
Weight
16.65 g
Nutrition
• Current consumption
  450 mA (USB 2.0)
  510 mA (USB 3.0) *
• Operating Voltage: 5.0 VDC ± 10%
Temperature
• Operating: 0 to 40 C
• Storage: -20 to 75 C
Humidity
• Operating: 10% to 90% (non-condensing)
• Storage: 5% to 95% (non-condensing)
Certifications
• FCC Class B
• IC
• CE
• C-Tick
• Wi-Fi Certified
All references to speed are for comparison only. Product specifications, size and shape are subject to change without notice, and actual product appearance may differ from that depicted on the packaging. The warranty card is inside the packaging.
Çözümler
Sipariş Bilgisi
Görseller
DWA-182/Ax
Front view
View from the right
View from the right
İndir
Destek Merkezi
