DWA-548EOL
802.11n Wireless Adapter PCI Express, up to 300 Mbit / s
Nereden Alınır
Tanımlama
The increased speed and extended the range of the network
Wireless Adapter PCI Express Wireless N 300 DWA-548 allows you to connect to high-speed wireless network. Extended range and increased speed guarantee a fast and reliable connection anywhere in your home.
Benefits of PCI Express
PCI Express offers higher bandwidth, increased productivity and allows you to connect an adapter DWA-548 PCIe slot to any computer - x1, x4, x8, or x16.
Connecting to the network
This adapter is based on Wireless N technology delivers high performance wireless network. DWA-548 is designed for use in bigger homes and for users who need high speed data transmission for the network. The adapter can be connected to a wireless router Wireless N from anywhere in the house. DWA-548 is also backward compatible with 802.11g and 802.11b and supports encryption WPA and WPA2, and that ensures the safety of your wireless network.
Easy to install and use
Quick Setup Wizard provides step by step instructions, you can configure this adapter without the help of a specialist. The package includes a utility for managing wireless connections (Wireless Manager), which allows you to track the most frequently accessed networks. Thanks to its high performance, excellent reception and enhanced security, this adapter is the perfect choice to create or improve connectivity desktop computers to a wireless network.
Genel Özellikler
Fiziksel Özellikler
OS Support
Windows 7, Vista, XP SP3
Standards
• IEEE 802.11n
• IEEE 802.11g
• IEEE 802.11b
Frequency band
• 802.11b: 2400-2497 MHz
• 802.11g: 2400-2483,5 MHz
• 802.11n: 2400-2483,5 MHz
Interface
PCI Express (PCIe)
Safety
• Wi-Fi Protected Access (WPA ™ and WPA2 ™)
• 64/128-bit WEP-encryption
• Wi-Fi Protected Setup - PIN and PBC
Antenna
Detachable dipole antenna, 2 dBi
LED diagnostics
Activity
Wireless speed
• IEEE 802.11b: 1, 2, 5,5, 11 Mbit / s
• IEEE 802.11g: 6, 9, 12, 18, 24, 36, 48, 54 Mbit / s
• IEEE 802.11n: from 6.5 to 300 Mbit / s
Transmitter power
• 802.11b
  16 ± 2 dBm to 1, 2, 5,5, 11 Mbit / s
• 802.11g
  17 ± 2 dBm to 6, 9, 12, 18, 24 Mbit / s
  15 ± 2 to 36 dBm, 48 Mbit / s
  14 ± 2 dBm at 54 Mbit / s
• 802.11n (mode HT20)
  14 ± 2 dBm for MCS0-MCS7
• 802.11n (mode HT40)
  12 ± 2 dBm for MCS0-MCS7
Receiver Sensitivity
• 802.11b
  -76 DBm to 1 Mbit / s
  -76 DBm to 2 Mbit / s
  -76 DBm to 5.5 Mbit / s
  -76 DBm to 11 Mbit / s
• 802.11g
  -82 DBm to 6 Mbit / s
  -81 DBm to 9 Mbit / s
  -79 DBm to 12 Mbit / s
  -77 DBm to 18 Mbit / s
  -74 DBm to 24 Mbit / s
  -70 DBm to 36 Mbit / s
  -66 DBm to 48 Mbit / s
 -65 DBm to 54 Mbit / s
  -80 DBm for MCS0
  -77 DBm for MCS1
  -75 DBm for MCS2
  -72 DBm for MCS3
  -68 DBm for MCS4
  -64 DBm for MCS5
  -63 DBm for MCS6
  -62 DBm for MCS7
  -77 DBm for MCS0
  -74 DBm for MCS1
  -72 DBm for MCS2
  -69 DBm for MCS3
  -65 DBm for MCS4
  -61 DBm for MCS5
  -60 DBm for MCS6
  -59 DBm for MCS7
The physical parameters
Operating voltage
3.3 V DC + / - 10%
Operating temperature
From 0 to 40 C
Storage temperature
-20 To 75 C
Operating Humidity
From 10% to 90% non-condensing
Humidity
From 5% to 95% non-condensing
Sizes 1
63,5 x 55 x 11,42 mm
Weight
42.5 g
Certifications
• CE Class B
• IC
• Wi-Fi
• CE
1 Size of the device without antenna
Çözümler
Sipariş Bilgisi
Görseller
DWA-548/B1
Front view
View from the right
DWA-548/A1
Front view
Front view
İndir
Destek Merkezi
