DWA-548EOL EOS
802.11n Wireless Adapter PCI Express, up to 300 Mbit / s
Tanımlama
The increased speed and extended the range of the network
Wireless Adapter PCI Express Wireless N 300 DWA-548 allows you to connect to high-speed wireless network. Extended range and increased speed guarantee a fast and reliable connection anywhere in your home.
Benefits of PCI Express
PCI Express offers higher bandwidth, increased productivity and allows you to connect an adapter DWA-548 PCIe slot to any computer - x1, x4, x8, or x16.
Connecting to the network
This adapter is based on Wireless N technology delivers high performance wireless network. DWA-548 is designed for use in bigger homes and for users who need high speed data transmission for the network. The adapter can be connected to a wireless router Wireless N from anywhere in the house. DWA-548 is also backward compatible with 802.11g and 802.11b and supports encryption WPA and WPA2, and that ensures the safety of your wireless network.
Easy to install and use
Quick Setup Wizard provides step by step instructions, you can configure this adapter without the help of a specialist. The package includes a utility for managing wireless connections (Wireless Manager), which allows you to track the most frequently accessed networks. Thanks to its high performance, excellent reception and enhanced security, this adapter is the perfect choice to create or improve connectivity desktop computers to a wireless network.
Genel Özellikler
Çözümler
Sipariş Bilgisi
Görseller
DWA-548/A1
Front view
View from the right
DWA-548/B1
Front view
View from the right
İndir
Destek Merkezi
