DAP-1420
Wireless 5 GHz (802.11a / n) access point / bridge to transmit HD video, up to 300 Mbit/s
Nereden Alınır
Tanımlama
Streaming HD video
Wireless Access Point / Bridge D-Link (DAP-one thousand four hundred and twenty) transmits multimedia stream high-definition (HD) via a wireless connection. DAP-1420 supports Ethernet-connected devices such as game consoles, digital video recorders (DVR), and media adapters (DMA).
High speed data transfer and performance
Built-in antennas provide high speed and reliable data transfer and performance, allowing you to enjoy watching streaming HD-video and play games online without delay. DAP-1420 also supports Intelligent Antenna, allowing to transmit multiple streams of data, eliminating "dead" zones and receive wireless signals, even in remote parts of the house.
Improved performance wireless network
Using the less congested 5 GHz band to avoid interference from other devices that provides increased performance and maximum wireless data rate, so you get the opportunity to view high-quality video and other media content.
Quality of service (QoS)
DAP-1420 supports Quality of Service (QoS), which provides prioritization of network traffic, such as VoIP, streaming HD video and games online.
Genel Özellikler
Fiziksel Özellikler
Standards
• IEEE 802.11a
• IEEE 802.11n
• IEEE 802.3
• IEEE 802.3u
• IEEE 802.3ab
Device Interfaces
• Button Wi-Fi Protected Setup ™ (WPS)
• Port 1 x 10/100 LAN
Modes of operation
• The access point
• Client Mode
Antenna Type
Flush antenna
Safety
• Wi-Fi Protected Access ™ (WPA ™, WPA2 ™)
• Wi-Fi Protected Setup (WPS)
Indicators
• Power
• Status: Wireless LAN
• Status: LAN
Frequency band
5.15 - 5.85 GHz
Wireless speed
• IEEE 802.11a: 6,9,12,18,24,36,48,54 Mbit / s
• IEEE 802.11 n: 300 Mbit / s 1
The output power of the transmitter
• IEEE 802.11a (5.15 ~ 5.25 GHz)
  16 dBm (± 1.5 dBm) at 6,9,12,18,24,36,48,54 Mbit / s
• IEEE 802.11a (5.725 ~ 5.825 GHz)
  17 dBm (± 1.5dBm) at 6 Mbit / s
  16 dBm (± 1.5dBm) at 6,9,12,18,24,36,48,54 Mbit / s
• IEEE 802.11 n:
HT-20 HT-40
MCS 5.15 GHz ~ 5.25 5.725 ~ 5.825 GHz MCS 5.15 GHz ~ 5.25 5.725 ~ 5.825 GHz
0 13dBm ± 1.5dBm 17dBm ± 1.5dBm 0 16dBm ± 1.5dBm 17dBm ± 1.5dBm
1 1
14dBm ± 1
5dBm
2 2
3 3
4 4
5 5
6 16dBm ± 1.5dBm 6 16dBm ± 1.5dBm
7 14dBm ± 1.5dBm 7 14dBm ± 1.5dBm
8 13dBm ± 1.5dBm 16dBm ± 1.5dBm 8 13dBm ± 1.5dBm 16dBm ± 1.5dBm
9 9
10 10
11 11
12 12
13 13
14 14
15 14dBm ± 1.5dBm 15 14dBm ± 1.5dBm
Receiver Sensitivity
• IEEE 802.11a
  -69 DBm (± 2dBm) pri54 Mbit / s
• IEEE 802.11 n (HT20 / 5 GHz)
  -65dBm (± 2dBm) at MCS = 15
• IEEE 802.11 n (HT40 / 5 GHz)
  -63dBm (± 2dBm) at MCS = 15
Fiziksel Özellikler
Power consumption
• TX: 12V / 0.44A
• RX: 12V / 0.385A
Minimum system recommendations
A computer with:
• Windows 7 2 , Windows Vista 2 , Windows XP SP3 2 or Mac OS X (v10.4) 3
• Internet Explorer v7
• Network Interface Card
For Internet access:
• Cable or DSL modem
• Subscribe to a package of services provider (ISP)
Scope of delivery
• Wireless Mediamost
• 1 Ethernet cable
• 1 Power Adapter
• Quick Installation Guide
Certifications
• FCC Class B
• UL
• CE
Temperature
• Operating: 0 ° C to 40 ° C
• Storage: -20 ° C to 80 ° C
Dimensions (L X W X H)
• Device: 167.8 x 119.8 x 31.3 mm
• With stand: 185.0 x 119.8 x 31.3 mm
1 Maximum wireless signal rate derived from the specifications standard 802.11n. Actual data throughput will vary. The conditions under which the network operates, as well as environmental factors, including volume of network traffic, building materials and construction, and network overhead, lower actual throughput. Wireless signal range can be affected by environmental factors. The maximum capacity is provided using standard 802.11n.
2 computer meets the system requirements recommended by Microsoft.
3 The software included with this product is not compatible with Mac.
 Product specifications, size and shape are subject to change without notice, and actual product appearance may differ from the one shown here.
Çözümler
Sipariş Bilgisi
Görseller
DAP-1420/B1
Back view
Front view
İndir
Destek Merkezi
