Hızlı Arama
Ürün Özellikleri:
Dual-polarized directional antenna for external use, 2.4 GHz
EOL EOS
Genel Özellikler:
Fiziksel Özellikler
Frequency band
From 2.4 GHz to 2.5 GHz
Resistance
50 ohms
Gain
11dBi (2.4 GHz)
VSWR
2.0: 1 (max)
The maximum gain
16-17 dBi
Radiation pattern in the horizontal plane (HPBW / H-PLANE)
18 ° - 25 °
Radiation pattern in the vertical plane (HPBW / V-PLANE)
18 ° - 25 °
Polarization
Linear, vertical / horizontal
The ratio of foreground and background signal levels (PZO)
-25dB (max)
Cross-polarization isolation
16dB (minimum)
Fiziksel Özellikler
Cable
2 RP-SMA cable access points designed for indoor use
Jack
Two N-type connector
Allowable Power
6 W (cw)
Lightning Protection
DC Ground
Wind Load
216 km / h
Operating temperature
From -40 ° C to 80 ° C.
Operating Humidity
95% at 55 ° C.
The color and material
Gray-white, PC UV Resistant
Weight
1.1 kg
Measurements
320 x 320 x 43 mm
Impermeability
IP67
Mount Kit
Pole Mount and Wall
Ürünler | Destek  | Haberler  | Hakkında |
