DAP-2310
AirPremier N ™ Wireless 2.4 GHz (802.11b/g/n) access point, up to 300 Mbit / s
Nereden Alınır
Tanımlama
Access Point DAP-2310 supports the 802.11n standard is the ideal solution for building or increasing the capacity of wireless networks. This access point is used primarily for networking in public places such as airports, coffee shops, shopping malls, sports facilities and campuses. Access Point DAP-2310 can function as a base station for connecting to a wireless network device of the standards 802.11b, 802.11g and 802.11n.
Multifunctionality
DAP-2310 allows you to create a manageable and reliable wireless network 802.11n. Two detachable antennas provide optimal wireless coverage in the 2.4GHz band (802.11g and 802.11n) using the increased power of the transmitter, which helps eliminate "dead zones" and increase throughput.
Increase in productivity
DAP-2310 provides wireless connectivity at speeds up to 300 Mbit / s in the 2.4 GHz band. Support for Wi-Fi Multimedia (WMMTM ) Quality of Service makes it an ideal access point for audio, video, and voice applications. In addition, DAP-2310 supports load balancing to ensure maximum performance by limiting the number of users per access point.
Safety
To provide a comprehensive network protection, DAP-2310 supports the latest wireless security technologies, using both versions of the data encryption standard Personal and Enterprise WPA and WPA 2 (802.11i) with support for server, RADIUS, which allows users to create their own accounts. In addition, the access point supports MAC-address filtering, segmentation of the wireless LAN, barring the broadcast SSID, the detection of illegal connections and wireless network performance in Broadcast Scheduling. DAP-2310 supports up to 8 VLAN, which allows multiple SSID for the implementation of network segmentation. DAP-2310 also supports wireless client isolation mechanism, which limits direct "client-client."
Modes of operation
To optimize network performance DAP-2310 can be configured in any of the following modes: Access Point, Wireless Client, WDS, and WDS with AP. With WDS support, network administrators can install multiple access points DAP-2310 and configure them to bridge, providing customers with access to a private network. In the AP DAP-2310 also incorporates advanced features such as load balancing (for optimal voice traffic on the network) and redundancy (for fail-safe wireless connection). In addition, support for Spanning Tree Protocol to more efficient data transmission by avoiding broadcast storm mode WDS.
Network control
The access point supports a variety of control options, including Web-based (HTTP), Secure Socket Layer (SSL), provides a secure connection to the Internet), Secure Shell (SSH, to provide a secure channel between computers), and Telnet (bi-directional, 8 - bit byte oriented communications facility). For advanced network management, you can use the D-Link AP Manager II or D-View module SNMPv3 to configure and manage multiple access points from a single computer. In addition to a management, AP Manager II and D-View allows network administrators to automatically carry out the inspection of equipment without loss of time and resources. Thanks to the work in the frequency range of 2.4 GHz, the advanced management features several modes of operation and improved security settings, access point D-Link AirPremier N (DAP-2310) is the ideal solution for wireless networking in business class.
Genel Özellikler
Fiziksel Özellikler
Standards
• IEEE 802.11n
• IEEE 802.11g
• IEEE 802.3ab
• IEEE 802.3u
• IEEE 802.3
Management
• Telnet - Secure (SSH) Telnet
• Web-browser
• HTTP - Secure HTTP (HTTPS)
• Support for SNMP
• The D-View - Private MIB
• AP Manager II
• An array of access points
Safety
• WPA ™ - Personal
• WPA2 ™ - Enterprise
• WPA2 ™ - Personal
• 64/128-bit WEP-encryption
• Disable SSID Broadcast
• Access Control MAC-based
• Detection of unregistered network access points
Support for VLAN / SSID
802.1q/Multiple SSID (up to 8)
Quality of service (QoS)
• 4 priority queues
• WMM Wireless Priority
Wireless Frequency Bands
From 2.4 GHz to 2.4835 GHz
Wireless speed
• IEEE 802.11b: 11, 5.5, 2 and 1 Mbit / s
• IEEE 802.11g: 108, 54, 48, 36, 24, 18, 12, 9 and 6 Mbit / s
• IEEE 802.11n (2.4 GHz): Up to 300 Mbits / s 2
The output power of the transmitter
IEEE 802.11b
• 24 dBm (± 2dB) at 1, 2, 5.5, 11 Mbit / s
IEEE 802.11g
• 24 ± 2 dBm at 6 ~ 24 Mbit / s
• 22 ± 2 dBm at 36 Mbit / s
• 21 ± 2 dBm at 48 Mbit / s
• 20 ± 2dBm at 54 Mbit / s
HT20
• 22 ± 2dBm at MCS0 ~ 1
• 21 ± 2dBm at MCS2 ~ 3
• 20 ± 2dBm at MCS4
• 19 ± 2dBm at MCS5
• 18 ± 2dBm at MCS6
• 17 ± 2dBm at MCS7
HT40
• 21 ± 2dBm at MCS0 ~ 3
• 20 ± 2dBm at MCS4
• 19 ± 2dBm at MCS5
• 18 ± 2dBm at MCS6
• 17 ± 2dBm at MCS7
Receiver Sensitivity
IEEE 802.11b
•-76dBm at 1 Mb / s
•-76dBm at 2 Mbit / s
• -76 dBm at 5.5 Mbit / s
• -76 dBm for 11 Mbit / s
IEEE 802.11g
•-82dBm at 6 Mbit / s
•-81dBm at 9 Mbits / s
•-79dBm at 12 Mbit / s
•-77dBm at 18 Mbit / s
•-74dBm at 24 Mbit / s
•-70dBm at 36 Mbit / s
•-66dBm at 48 Mbit / s
•-65dBm at 54 Mbit / s
HT20
•-82dBm at MCS0
•-79dBm at MCS1
•-77dBm at MCS2
•-74dBm at MCS3
•-70dBm at MCS4
•-66dBm at MCS5
•-65dBm at MCS6
•-64dBm at MCS7
HT40
•-82dBm at MCS0
•-79dBm at MCS1
•-77dBm at MCS2
•-74dBm at MCS3
•-70dBm at MCS4
•-66dBm at MCS5
•-65dBm at MCS6
•-64dBm at MCS7
Modes of operation
• The access point (AP)
• WDS access point
• WDS / Bridge (No AP Broadcast)
• Wireless client
• Repeater (software version 1.15 or higher)
The gain of the dipole antenna
2 GHz dBi@2.4
The maximum power of the transmitter
FCC: 25 dBm / ETSI: 17dBm (Dual Chain)
Indicators
• LAN
• 2.4 GHz
Fiziksel Özellikler
The maximum power consumption
8 W
Operating voltage
5 V / 2A
Operating temperature
From 0 to 40 ° C
Storage temperature
-20 To 65 ° C
Operating Humidity
From 10% to 90% (non-condensing)
Humidity
From 5% to 95% (non-condensing)
Certifications
• FCC Class B
• CE
• WiFi ®
Weight
238 g
Measurements
111 x 28 x 148 mm
1 This device is intended for indoor use. Installing the outside can lead to a violation of local regulations.
2 Maximum wireless signal rate derived from the specifications of 802.11g and 802.11n. Actual data throughput will vary. The conditions under which the network operates, as well as environmental factors, including volume of network traffic, building materials and construction, and network overhead, lower actual throughput. Wireless signal range can be affected by environmental factors.
Çözümler
Sipariş Bilgisi
Görseller
DAP-2310/Ax
Front view
View from the right
Back view
İndir
Destek Merkezi
