Hızlı Arama
Ürün Özellikleri:
Set of two adapters PowerLine AV + DHP-308AV
Genel Özellikler:
Fiziksel Özellikler
PowerLine Interface
Power connector (depending on country)
Ethernet Interface
• Port Fast Ethernet
• RJ-45 connector
Standards
• IEEE 802.3
• IEEE 802.3u
• HomePlug AV
• IEEE 1901
Safety
128-bit AES data encryption
Indicators
• Power
• Ethernet
• PowerLine
The modulation scheme PowerLine
Symbol OFDM modulation
Bandwidth PowerLine
From 2 MHz to 68 MHz
Data rate
• PowerLine: More than 200 Mbit / s (PHY rate) 2
• Ethernet: 10/100 Mbit / s (Auto-Negotiation)
Fiziksel Özellikler
Measurements
70 x 52 x 26 mm
Power Input
100-240 VAC, 50/60 Hz
Saving energy
Support power saving mode
Temperature
Working from 0 to 40 C
Humidity
Operating: 10% to 90% (non-condensing)
Certifications
• CE LVD
• FCC
• UL
• CE EMC Class B
2 Products PowerLine AV + are equipped with more powerful CPU than providing data transfer rate 200 Mbit / s products PowerLine AV, to increase performance and network coverage. Maximum throughput based on theoretical transmission PHY rate of the data.Actual data throughput will vary. The conditions under which the network operates, as well as environmental factors, including volume of network traffic, and network overhead, lower actual throughput. Interference from devices that produce electrical noise, such as vacuum cleaners and hair dryers can reduce the performance of the product. This product may cause interference and prevent the operation of devices such as lighting with dimmer switch or a touch-button on / off switch, short wave radio communication devices or other devices PowerLine, do not meet the standard HomePlug AV.
Ürünler | Destek  | Haberler  | Hakkında |
