DHP-540EOL EOS
PowerLine AV switcher c 4 Gigabit ports
Tanımlama
	Data transmission on the wiring
	PowerLine AV Switch DHP-540 with 4 Gigabit Ethernet ports allows you to use existing electrical wiring to create a home network or extend the range of your wireless network1. The switch is included in the wall socket allows you to connect multiple devices to the network by: digital media devices, game consoles, print servers, computers and network storage devices. DHP-540 complies with IEEE 1901 and HomePlug AV, and can be used with devices PowerLine earlier.
	The ideal solution for applications that require high bandwidth
	DHP-540 provides data transfer rates of up to 500 Mbit / s 2 , which makes the device an ideal solution for applications that require high bandwidth, providing streaming HD-video, VoIP-telephony and online games without delay. In addition, the switch supports the prioritization of Internet traffic, providing the performance of multimedia applications while viewing Web-pages and downloads. The device provides wide bandwidth, providing users with selecting a digital home technologies, the ability to use existing wiring for streaming high quality video.
	Easy installation and safety
	Extend the range of your home network by connecting multiple devices from the most distant points of the house, or create additional connection by connecting a switch or wireless access point to the DHP-540. The adapter supports 128-bit AES data encryption to protect the network from unauthorized connection to the line. With simple installation Plug and Play, DHP-540 is the ideal solution to create a home network.
	Power Saving Function
	DHP-540 supports the conservation of energy, including standby mode automatically if, within a certain period of time is not being transmitted or received, or no device is connected to the ports. This may continue for more than 50% of the energy.
