Hızlı Arama
Ürün Özellikleri:
PowerLine AV switcher c 4 Gigabit ports
Genel Özellikler:
Fiziksel Özellikler
Standards
• IEEE 802.3
• IEEE 802.3h
• IEEE 1901
• HomePlug AV
PowerLine Interface
Power connector (depending on country)
Ethernet Interface
• 4-port 10/100/1000BASE-T Ethernet with auto-crossover MDI / MDIX
• RJ-45 connector
Frequency range PowerLine
From 2 MHz to 70 MHz
Data rate 2
• PowerLine: up to 500 Mbit / s (the speed supported by the chipset)
• Ethernet: 10/100/1000 Mbit / s (automatic speed change)
QoS
Built-in QoS traffic prioritization
Minimum System Requirements
(For computer utilities)
• Windows 7/Vista/XP SP3
• Ethernet interface
Indicators
• Power
• PowerLine
• Ethernet
Fiziksel Özellikler
Power Input
From 100 to 240 VAC, 50/60 Hz
Power Save
Support for the power save mode
Measurements
132 x 103 x 42 mm
Weight
250 grams
Operating temperature
From 0 ° to 40 ° C.
Operating Humidity
10 to 90% (non-condensing)
Certifications
• FCC Part 15 Class B
• CE EMC Class B
• CE LVD
• UL
1 power outlets and electrical wiring must be part of the same electrical system. Some conditions, such as laying electrical wiring, can affect the performance of the product. To add new devices to the network requires additional adapters D-Link PowerLine AV.To create a network requires at least two adapters D-Link PowerLine AV. Connecting this product to a power strip with a surge protector may adversely affect the performance of the product. For best results, plug the adapter directly into a wall outlet.
2 Maximum throughput based on theoretical data rate chipset. Actual data throughput will vary. The conditions under which the network operates, as well as environmental factors, including volume of network traffic, and network overhead, lower actual throughput. Interference from devices that produce electrical noise, such as vacuum cleaners and hair dryers can reduce the performance of the product. This product may cause interference and prevent the operation of such devices as lighting with dimmer switch or a touch-button on / off switch, short wave radio communication devices or other devices PowerLine, do not meet the standard HomePlug and IEEE 1901.
Ürünler | Destek  | Haberler  | Hakkında |
