Hızlı Arama
Ürün Özellikleri:
Wireless N Day/Night Network Camera
EOL
Genel Özellikler:
Camera
Camera Hardware Profile
• 1/5” VGA progressive CMOS sensor
• Fixed length 3.15 mm
• Aperture F2.8
• Angle of view
  • (H) 45.3°
  • (V) 34.5°
  • (D) 54.9°
• Exposure Time: 1/3.75 to 1/14,640 sec.
• 4X digital zoom
• Minimum object distance: 500 mm
• Built-in microphone
• 5 meter IR illumination distance
• Minimum illumination: 0 lux with IR LEDs on
• Built-in Infrared-Cut Removable (ICR) Filter module
Image Features
• Configurable image size, quality, and frame rate
• Time stamp and text overlays
• Configurable motion detection windows
• Configurable brightness, saturation, contrast
Video Compression
• MJPEG format compression
• JPEG for still images
Video Resolution
• 640 x 480 at 20 fps
• 320 x 240 / 160 x 112 at 30 fps
Audio
• PCM
Connectivity
• 10/100 BASE-TX Ethernet port
• 802.11n/b/g wireless with WEP/WPA/WPA2 encryption
• Operates over 2.4 GHz frequency band
• Single-band 1T1R mode supports a maximum data rate of 72.2 Mbps (PHY rate) using 20 MHz bandwidth
Network
Network Protocols
• IPv4
• ARP
• TCP
• UDP
• ICMP
• DHCP Client
• NTP Client (D-Link)
• DNS Client
• DDNS Client (D-Link)
• SMTP Client
• FTP Client
• HTTP Server
• PPPoE
• UPnP Port Forwarding
• LLTD
Security
• Password authentication
• HTTP digest encryption
System Integration
System Requirements for Web Interfaces
• Operating system: Microsoft Windows 8/7/Vista or Mac OS X 10.6 or higher
• Browser: Internet Explorer 7, Firefox 12, Safari 6, or Chrome 20 or higher with Java installed and enabled
Event Management
• Motion detection
• Event notification and sending snapshots via SMTP
• Sound level detection
Remote Management
• Configuration accessible via web browser
Mobile support
• mydlink Lite app for iPhone/iPad/iPod touch, Android, and Windows Phone
D-ViewCam™ System Requirements
• Operating System: Microsoft Windows 8/7/Vista/XP
• Web Browser: Internet Explorer 7 or higher
D-ViewCam™ Software Functions
• Remote management/control of up to 32 cameras
• Scheduled motion triggered, or manual recording
• Viewing of up to 32 cameras on one screen options
• Supports all management functions provided in web interface
Dimensions
• Camera only: 60 x 32.15 x 96 mm (2.36 x 1.27 x 3.78 in)
• With base: 80 x 80 x 126.6 mm (3.15 x 3.15 x 4.98 in.)
Weight
• Camera only: 57.8 grams (2.04 ounces) ± 5%
• With base: 91.8 grams (3.24 ounces) ± 5%
Power
• 5 V DC 1 A, 50/60 Hz
Power Consumption
• 2.84 watts maximum ± 5%
Temperature
• Operating: 0 to 40 °C (32 to 104 °F)
• Storage: -20 to 70˚ C (-4 to 158 ˚F)
Humidity
• Operating: 20% to 80% non-condensing
• Storage: 5% to 95% non-condensing
Certifications
• CE
• IC
• FCC Class B
• C-Tick
Dimensions Diagram
 size
Fiziksel Özellikler
Ürünler | Destek  | Haberler  | Hakkında |
