DCS-1201 HD Covert Network CameraEOL
1 MP modular network camera with PoE, WDR, color imaging in low light and microSD card slot
Nereden Alınır
Tanımlama
Installs Anywhere
This tiny camera can easily be placed in walls or ceilings, or in tight corners, and the 15 meter camera cable gives you a wealth of installation options.
High Quality Footage
The DCS-1201 camera may be small, but it delivers HD video at 720P, giving you a sharp image with the detail you need.
Simple to Maintain
The DCS-1201 is a stand-alone system with a built-in CPU, requiring no special hardware or software. The DCS-1201 can be viewed and managed through most web browsers, including Internet Explorer.
Supports a Variety of Platforms
With support for TCP/IP networking, HTTP, and other Internet related protocols, the DCS-1201 can also be integrated easily into other Intranet applications because of its standards-based features. The DCS-1201 works with any 10/100 Ethernet network, making the DCS-1201 easy to integrate into your existing network environment.
Advanced Event Management
The DCS-1201 can be set up to send e-mail notifications with snapshots when an event occurs, such as when motion is detected. Events can be triggered from several sources, such as motion detection and time based events.
PoE (Power over Ethernet) for Flexible Installation
The DCS-1201 can draw all the power it needs from a PoE switch or PoE injector for a simple and clutter-free installation.
Genel Özellikler
Fiziksel Özellikler
• Minimum object distance 0.5 m
• Lens focal length: 2.8 mm
• Aperture: F2.0
• Angle of view (16:9):
(H) 84 °• (V) 44 °• (D) 100 °
Image Features
• Configurable image size, quality, frame rate, and bit rate
• Time stamp and text overlays
• Configurable motion detection windows
• Configurable privacy mask zones
• Configurable exposure time, brightness, saturation, contrast, sharpness
• Wide Dynamic Range (WDR)
• 3D filtering
Video Compression
• Simultaneous H.264/MPEG-4/MJPEG format compression
• H.264/MPEG-4 multicast streaming
• JPEG for still images
Video Resolution
• 16:9 - 1280 x 720, 800 x 450, 640 x 360 at up to 30 fps1
• 4:3 - 1024 x 768, 800 x 600, 640 x 480 at up to 30 fps1
Audio Support
• G.711
External Device Interfaces
• 10/100 BASE-TX Ethernet port with PoE (Class 2)
• 1 DI / 1 DO
• DC12 V, 100 mA Output
• Camera port
• Power terminal (8 ~ 28 V DC)
• micro SD/SDHC/SDXC card Slot, accepts cards up to 64 GB
• Audio input / output
Network Protocols
• IPv6• IPv4• TCP/IP• UDP• ICMP• DHCP client• NTP client (D-Link)• DNS client• DDNS client (D-Link)• SMTP client• FTP client• HTTP / HTTPS• Samba client• PPPoE• UPnP port forwarding• RTP / RTSP/ RTCP • IP filtering• QoS• CoS• Multicast• ONVIF compliant• SNMP• Bonjour
Security
• Administrator and user group protection
• Password authentication
• HTTP and RTSP authentication
Çözümler
Sipariş Bilgisi
Görseller
DCS-1201 HD Covert Network Camera/Ax
Back view
Front view
İndir
Destek Merkezi
