DCS-7513Proje
External Full HD camcorder with a sensor WDR Day & Night Shooting
Nereden Alınır
Tanımlama
External Full HD Video Camera D-Link DCS-7513 is the ideal solution for creating a system of professional high-definition video, and security of small, medium and large enterprises. Highly sensitive megapixel WDR CMOS-sensor with progressive scan provides excellent image quality in various lighting conditions. Rugged dustproof and waterproof design allows you to set the camera in a variety of places without the need for additional accessories.
High Quality Video
Video Camera DCS-7513 is equipped with a P-Iris, providing automatic iris control with high precision. Built-in lens step motor optimizes the opening of the diaphragm in all lighting conditions, thus ensuring high quality, sharpness and depth of field image.The remote focus eliminates the need to manually focus and allows you to set up the camera from any computer. To maximize bandwidth efficiency and improve image quality Camera DCS-7513 provides video compression in real-time formats, H.264, MPEG-4 and MJPEG and supports three separate profiles for simultaneous streaming and recording video. Support for these features enhances security, including video surveillance in public places in order to detect incidents and coordinate appropriate responses, monitoring restricted areas, prevention of criminal acts or supervision of property.
Continuous monitoring
Video Camera DCS-7513 with the WDR sensor provides improved image quality but with uneven lighting, thus allowing to identify the subject lit from behind, or shooting in very bright light. Built-in infrared LEDs (up to 30 meters) automatically according to the lighting conditions and allows the camera to conduct surveillance in total darkness. Thanks to the combination of these functions Camera DCS-7513 is ideal for day and night surveillance.
Reliable management software
As with the camera DCS-7513 includes D-ViewCam - complete video surveillance software that lets you view images, manage, and to record up to 32 cameras on a single computer. In addition, the available video recording functions and e-mail alerts when motion is detected or when the signal on the digital input. Connectivity
Support for Power over Ethernet 802.3af simplifies the installation of the device by transmitting the power and network connectivity, one Ethernet-cable, eliminating the need for additional power cables. In addition, the digital inputs and outputs allow you to connect external devices such as IR sensors, switches and signal relay.
Genel Özellikler
Fiziksel Özellikler
Camera Hardware Profile
·         1/2.8”  2 Megapixel progressive CMOS sensor
·         30 meter IR illumination distance
·         Minimum illumination: 0 lux with IR LEDs on
·         Built-in Infrared-Cut Removable (ICR) Filter module
·         10x digital zoom
·         3 to 9 mm motorised varifocal lens
·         Aperture: F1.2
·         Angle of view (16:9)
·         (H) 121.2° to 38.1°
·         (V) 62.1° to 21.3°
·         (D) 148.4° to 43.8°
Camera Housing
·         IP-66 compliant weatherproof housing
·         Cable management bracket
Image Features
·         Configurable image size, quality, frame rate, and bit rate
·         Time stamp and text overlays
·         Configurable motion detection windows
·         Configurable privacy mask zones
·         Configurable shutter speed, brightness, saturation, contrast, sharpness, zoom, focus, and aperture
Video Compression
·         Simultaneous H.264/MPEG-4/MJPEG format compression
·         H.264/MPEG-4 multicast streaming
·         JPEG for still images
Video Resolution
·         16:9 at 1920 x 1080,1280 x 720, 800 x 450, 640 x 360, 480 x 270, 320 x 176, 176 x 144 up to 30 fps
·         4:3 at 1440 x 1080, 1280 x 960, 1024 x 768, 800 x 600, 640 x 480, 320 x 240, 176 x 144 up to 30 fps
Audio Support
·         G.726
·         G.711
External Device Interface
·         10/100 BASE-TX Ethernet port with PoE
·         1 DI / 1 DO
·         DC12 V, 100 mA output
·         SD/SDHC card slot
·         Audio input/output
·         DI/DO connector 12 V DC output
Network Protocols
·         IPv6
·         IPv4
·         TCP/IP
·         UDP
·         ICMP
·         DHCP client
·         NTP client (D-Link)
·         DNS client
·         DDNS client (D-Link)
·         SMTP client
·         FTP client
·         HTTP / HTTPS
·         Samba client
·         PPPoE
·         UPnP port forwarding
·         RTP / RTSP/ RTCP
·         IP filtering
·         QoS
·         CoS
·         Multicast
·         IGMP
·         ONVIF compliant
Security
·         Administrator and user group protection
·         Password authentication
·         HTTP and RTSP digest encryption
System Requirements for Web Interface
·         Browser: Internet Explorer, Firefox, Chrome, or Safari
Event Management
·         Motion detection
·         Event notification and uploading of snapshots/video clips via e-mail or FTP
·         Supports multiple SMTP and FTP servers
·         Multiple event notifications
·         Multiple recording methods for easy backup
Remote Management
·         Take snapshots/video clips and save to local hard drive or NAS via web browser
·         Configuration interface accessible via web browser
Operating Systems
·         Windows 7/Vista/XP/2000
D-ViewCam™ System Requirements
·         Operating System: Microsoft Windows 7/Vista/XP
·         Web Browser: Internet Explorer 7 or higher
·         Protocol: Standard TCP/IP
D-ViewCam™ Software Functions
·         Remote management
·         Control and manage up to 32 cameras
·         View up to 32 cameras on one screen
·         Management functions provided in web interface
·         Scheduled, motion detection, and manual recording triggers
Dimensions
·         223.5 x 97.5 x 90.7 mm
Weight
·         2050 g (with bracket and sunshield)
External Power Adapter
·         Input: 100 to 240 V AC, 50/60 Hz
·         Output: 12 V 1.25 A
Power Consumption
·         11.02 watts ± 5 %
Temperature
·         Operating: -40 to 50 °C (-40 to 122 °F)
·         Storage: -20 to 70° C (-4° to 158° F)
Humidity
·         Operating: 20% to 80% non-condensing
·         Storage: 5% to 95% non-condensing
Certifications
·         CE
·         CE LVD
·         FCC
·         C-Tick
Çözümler
Sipariş Bilgisi
Görseller
DCS-7513/Ax
Front view
İndir
Destek Merkezi
