Hızlı Arama
Ürün Özellikleri:
High-speed PTZ dome network camera with a 12x optical zoom
Genel Özellikler:
Fiziksel Özellikler
Camera
Hardware profile camera
• Sensor Sony Super HAD-II 1/4 "CCD
• Resolution 650 TVL
• Minimum illumination: 0.1 lux (color), 0.01 lux (B / W)
• Built-in ICR-filter
• Electronic shutter from 1 to 1/100000 seconds
• The ratio of the "signal-to-noise"> 50 dB (automatic gain control (AGC off)
• 12x optical zoom
• Fixed lens with a focal length: 3.8 to 45.6 mm
• Aperture: F1.6 to F2.7 from
• Viewing angle:
   of 4,49 ° to 52,8 ° (horizontal)
   of 3,40 ° to 39,7 ° (vertical)
   from 55,4 ° to 65,4 ° (diagonal)
Hardware profile PTZ
• Rotation: 360 °
• Tilt: 10 ° to 170 °
• Manually adjust the speed from 1 ° to 80 ° per second
• Preset points: 256 points
• The accuracy of the Pan / Tilt: 0,225 °
• The speed pan / tilt: 10 ° to 400 ° per second
• Number of independent paths when operating in Sequence: 8
• The number of independent paths when operating in Auto Pan: 4
• Number of independent paths when operating in Cruise: 8
• The speed of rotation is proportional to the tilt and zoom level
• Resume after power loss
• Functions of Home: Preset, Sequence, Auto Pan, Cruise
• Automatic coup: the mechanical / digital / off
• Digital Slow Shutter
• Pause
• Image flip
Image Functions
• Setting the image size and quality, frame rate and bit rate
• The timings and paste text
• Customizable windows for motion detection
• 16 customizable areas of private masks
• Setting the white balance, shutter speed, brightness, color saturation, contrast and sharpness
Video Compression
• Video compression formats H.264/MPEG-4/MJPEG
• JPEG for still images
Video Resolution
• NTSC: 720 x 480, 352 x 240, 176 x 120 at frame rates up to 30 frames / s
• PAL: 720 x 576, 352 x 288, 176 x 144 at frame rates up to 25 frames / s
Sound support
G.726
External device interfaces
• Port 10/100 BASE-TX Ethernet
• 8 input alarm sensors
• 1 alarm output sensor
• Audio In / Out
• Video
Network
Network Protocols
IPv4, TCP / IP, UDP, ICMP, DHCP-Client, NTP-Client (D-Link), DNS-client, DDNS-Client (D-Link), SMTP-client, FTP-client, HTTP / HTTPS, Samba- client, PPPoE, port forwarding UPnP, RTP / RTSP / RTCP, filtering on IP-addresses, 3GPP, IGMP, ONVIF compliance
Safety
• Security administrator account and user groups
• Password authentication
System control
System requirements for Web-based interface
• Operating System: Microsoft Windows 7/Vista/XP/2000
• Browser: Internet Explorer, Firefox, Netscape, Opera
Event Management
• Motion detection
• Event notification and download stop-kadrov/videoklipov via HTTP, SMTP or FTP
• Supports multiple HTTP, SMTP and FTP-servers
• Multiple event notifications
• Several ways to create backups
Remote management
• Configuring via Web-browser
• Get stop-kadrov/videoklipov and save to your local hard drive or NAS via Web-browser
Support for mobile devices
The system Windows 7/Vista/XP, Pocket PC or mobile phone with 3GPP playback support
System Requirements D-ViewCam ™
• Web-browser: Internet Explorer 6 or higher
• Protocol: The standard TCP / IP
The software features D-ViewCam ™
• Remote management / control of up to 32 cameras
• View up to 32 cameras on one screen
• Supports all management functions provided in the Web-interface
• Schedule of events to trigger or manual recording
Fiziksel Özellikler
Power Input
12 V DC, 2 A
The maximum power consumption
14 W
Operating temperature
From 0 ° to 40 ° C
Storage temperature
-20 ° to 70 ° C
Humidity
From 20% to 80% non-condensing
Weight
1.2 kg
Certifications
CE (Class A), CE LVD (EN60965-1), FCC (Class A), ICES-003, C-Tick
Measurements
Ürünler | Destek  | Haberler  | Hakkında |
