Hızlı Arama
Ürün Özellikleri:
HD Wireless N Pan & Tilt Network Camera
Tanımlama:
Tanımlama:
The DCS-5222L HD Wireless N Pan & Tilt Network Camera is a wireless pan/tilt network camera with megapixel resolution designed for indoor surveillance applications and detailed remote monitoring. The camera is also mydlink™-enabled, which provides user-friendly setup and instant remote viewing through the mydlink website or through the mydlink app for iOS and Android devices.
Full-featured Wireless Surveillance Camera
The DCS-5222L HD Wireless N Pan & Tilt Network Camera is ideal for small and medium business applications which require coverage of a large area, or remote monitoring. It gives you detailed, 24-hour remote surveillance of a large area by using a megapixel high-resolution HD image sensor for high-quality video and a built-in IR illuminator for low-light surveillance. The DCS-5222L can also be connected to your network wirelessly, allowing you to place the camera anywhere that has a Wi-Fi signal, eliminating the need to install additional network cabling.
A Complete Surveillance System
The DCS-5222L includes a built-in CPU, allowing it to function as a complete, standalone surveillance tool. Recordings can be made continuously, whenever movement is detected, or according to a predefined schedule. E-mail notifications can be sent when specific events occur, keeping you informed of what is hapenning, no matter where you are. The built-in microSD slot allows the camera to record independently, or can serve as a backup to continuously record video even if the network connection is lost. The DCS-5222L can also be used as part of a multi-camera surveillance system through the included D-ViewCam software, which supports up to 32 cameras.
Sharp Image Monitoring from Different Angles
With sharp, responsive pan/tilt movement and digital zoom, the HD Wireless N Pan & Tilt Network Camera gives you full control, so you can quickly scan a wide area from a variety of angles, and 4x digital zoom lets you zoom in on specific areas for more detail. The DCS-5222L can also be set to automatically move to specific preset positions, allowing the camera to patrol particular areas of interest within a surveillence area.mydlink-enabled for Simple Setup and Convenient.
Remote Monitoring
D-Link’s convenient mydlink zero-configuration setup gets you up and running in no time – just connect the DCS-5222L to a mydlink-enabled router, and your camera will automatically configure itself and appear in your mydlink account. Once connected, use the mdlink website to give you convenient access to your video feeds from any internet-connected PC. You can even view your camera feeds on your smart phone or tablet with the mydlink iOS and Android apps, so you can keep an eye on things even while on the go.
Ürünler | Destek  | Haberler  | Hakkında |
