Hızlı Arama
Ürün Özellikleri:
Network Yönetim Yazılımı
Genel Özellikler:
Fiziksel Özellikler
MIB Utilities
·         Device SNMP Configuration
·         MIB II Information and Statistics
·         IF Information Tables
·         Spanning Tree Information and Port Configuration
·         Bridge 802.1d Information and Port Configuration
·         RMON Statistic, History and Event Group
·         Transparent Bridge Forwarding, Static Filter Tables and Port Counter
·         802.1p Priority Configuration
·         MIB Browser
·         MIB Compiler
System Management Tools
·         Performance Monitor (switch should support RFC1213 Interface and RMON)
·         Device Panel Simulation Module
·         Batch Program
·         Link Capacity Check
·         Safeguard Check
·         Get All Arp Information
·         Device Type Check
·         Topology Generator
·         Topology Import / Export
·         Hierarcial Topology Manager
·         Device Type Extension
·         Web Configuration
·         Telnet Configuration
·         TFTP file transport
·         Traceroute
·         MAC Locator
·         Ping
Fault Management Tools
·         Trap Filter
·         Trap Log
·         Ping Poll Filter
·         Ping Poll Log
·         SNMP Poll Filter
·         SNMP Poll Log
·         Event Config Manager
·         Event Viewer
Performance Management Tools
Security Management Functions
·         SNMP v3 covering security functions such as packet encryption/decryption, user levels for different classes of access right, MPD (RFC 2572), TARGET (RFC 2573), USM (RFC 2574) and VACM (RFC 2575)
·         SNMP v3 Configuration
·         Device Module Access Right Control
·         NMS System Access Control
·         NMS System Function Module Access Right Control
·         Local and Radius Authentication Modes when Login
Resource Management Functions
·         Device Resource Manager
·         User Locator
·         Device Locator
·         User Statistics
·         Device Statistics
·         Device System Information Manager (RFC 1213 System)
·         Device Port Status Manager
Supported Devices
·         Multi-layer switches
·         OLT/ONU devices
·         Wireless bridges and access points
·         Remote routers
·         Multi-tenant broadband CO devices
·         Device Panel Simulation for other vendor's devices
Ürünler | Destek  | Haberler  | Hakkında |
