D-View 7
Network Management System
Nereden Alınır
Tanımlama
The D-View 7 Network Management System is a comprehensive standards-based management tool designed to centrally manage critical network characteristics such as availability, reliability, resilience and security in a consistent way. Flexible and versatile, D-View 7 uses cutting edge web technology to provide a comprehensive software toolbox that can be accessed without the need to install software onto the client.
Flexible Architecture
D-View 7 is organized into a server-probe architecture, which simplifies data collection across complex networks. Monitoring and configuring multiple devices at remote locations, across the Internet, or behind a NAT is no longer an issue with the D-View 7. Remotely deployed probes will automatically tunnel home, allowing for the management of devices that cannot be directly accessed using standard SNMP. When a device is selected for management,  D-View 7 probes will relay the command to the devices and then report back its data to the D-View 7 server.
Simplify Network Management
D-View 7 supports various predefined configuration template which can help users manage multiple devices easily. For complex configuration, D-View 7 also has the ability to  deploy CLI scripts across multiple devices simultaneously. This allows D-View 7 to support a wide area network range of configuration features and virtually any device as long as it supports reporting, monitoring, analysing  and CLI settings. With a highly customizable scheduling system, D-View 7 can allow users to assign tasks to be issued in off peak hours or any other planned maintenance time frame. Users can have the peace of mind knowing that routine maintenance task and configurations will be automatically managed and monitored by D-View 7’s event notification system. D-View 7 also supports periodic task which can be run daily, weekly, monthly, etc.
Extendable, Affordable Business Wireless Solution
Designed from the ground up as a standalone software controller, D-Link D-View 7 is flexible, robust, and feature rich. It comes ready to run with many enhanced enterprise wireless access point (AP) features to provide a solid wireless network system for customers who need a centralized management controller. D-View 7 can be deployed onto a server running Microsoft Windows and can manage up to 500 APs without an additional license charge. D-View 7 currently supports 6 different models of D-Link Access Points.
Robust Security and Management Tools
The D-View 7 Network Management System supports multi-site deployment management as well as multi-tenancy management. This allows network administrators to provide different management authorities between head and regional offices, and allows service providers to offer a managed wireless network for their customers. Sites can be logically separated with their own configuration, access security, network map, and statistics. Auto- generates network topology maps and periodically polls network devices. The map of the topology  view  can  be  modified(Add,  Edit, Delete).  Select  this  option  image  formats  supported are JPG, JPEG, GIF and PNG. For example, a network operations manager could pre-configure APs before dispatching them to regional offices. He can then manage all of the APs on an enterprise intranet, while allowing local administrators to manage APs that are only present on their local network. The service provider can simply send a pre-configured AP to a customer and then remotely manage the customer’s wireless network access and security.
Manage Third-party Devices
Network administrators can customize the SOID and related information of virtually any 3rd party device which lets D-View 7 identify many third party devices and manage them. D-View 7 can then check the health status of those devices, issue CLI commands, and do the standard management and monitoring. Detected foreign wireless access points seen on the Network Management System. Combined with the new D-View 7 graphical dashboard, network administrators can get near real-time feedback on the status of their network.
For wireless access, D-Link SMB APs can support 8 SSIDs per radio, which means administrators can use one SSID to create a guest network for visitors. D-View 7 expands on that built-in feature and allows for multiple user authentications. Access controls can be configured per SSID as well, allowing network administrators to configure separate internal networks for different subnets. This means that more advanced value added services such as a captive portal or Wi-Fi hotspots can be used to help manage wireless network traffic.
Flexible Expansion and Deployment Options
Unlike traditional hardware controller solutions for managing wireless access points, D-View 7  has a much lower initial investment cost as it comes bundled with many D-Link access points and there are no per access point license charges. With the simple to use installation tool, it is easy to expand the wireless network in the future. Adding devices to D-View 7 is done automatically when new access points are discovered on the network, allowing new devices to be quickly managed and deployed. D-View 7 also automatically manages RF output for multiple access points, optimizing the number of available wireless channels and coverage. This results in reduced channel interference and provides faster total bandwidth throughput and connection reliability. By optimizing the coverage area and connection quality, D-View 7 enables network administrators to provide better wireless service at a lower deployment cost, resulting in a higher return on investment.
Deploying D-View 7 is also much simpler compared to traditional hardware controller solutions as it can be installed on any server running a recent version of Microsoft Windows. D-View 7 software operates transparently on the network meaning the access point can be deployed anywhere in a customer’s Layer 2/3 environment. Management traffic to and from the target access points will go through an authorized  tunnel to D-View 7 while normal network traffic will go through existing networking infrastructure unimpeded. The D-View 7 management interface is also remotely accessible via its built-in web server. Administrators can use a web browser to connect to computers with D-View 7  installed to manage their WLAN network and wireless access points from anywhere.
Enhanced Trap and Syslog Analysis
D-View 7 also functions as a trap and syslog server which can collect all of the trap or syslog data from multiple devices across a network. This gives network administrators a centralized place to collect important data, which can then be searched easily from within one year retrospective recording D-View 7. The advanced search system lets network administrators set keyword combinations, and generate alarms based on events that are reported in the trap or syslog feature. It can also let network administrators set key works, keyword combinations, and generate alarms based on reported trap or syslog.
Genel Özellikler
Fiziksel Özellikler
Features
Simplify Management Tasks
Supports SNMP v1, v2c, and v3
Supports device auto-discovery
Supports scheduled and periodic task management
Supports event notification and event escalation
Supports SNMP trap and syslog collection
Supports Batch Configuration and is capable of configuring multiple devices at a time
Designed with a server and probe architecture
Supports management of devices behind a
firewall, NAT, or in remote sites without a VPN
Visualization
Easy to understand and configure dashboard
Customizable chart system for displaying data
Support auto-generates network topology
Support real-time device status on topology
Support real-time device rack and panel simulation
3rd Party Device Support
Support Smart and Managed Switches, Unified
Switches, Unified Access Points, Wireless
Controller, Wireless Access Point, etc.
Support 3rd party device management by MIB
Compiler and Browser
Web-based management
Software controller can be installed on a Microsoft Windows computer and accessed
through any device with a web browser such as a smartphone, tablet, or computer
Multi-site management
Multiple distributed sites can be managed from a central location
The multi-tenant architecture provides multilayer management authority
Wireless Acces Device connected allows access point locations, information on topologhy map and management features
NAT pass-through
Controllers can manage wireless access points in remote locations even if they are behind a NAT device (router or firewall)
Captive portal and access control
Supports local DB, external RADIUS, LDAP, POP3 and Wi-Fi passcode authentication
Supports user access control
Auto radio frequency (RF) management
Supports automatic channel and output power optimization
Real-time radio frequency status
Radio performance analyzer
Bandwidth optimization
Optimizes wireless bandwidth
Advanced Report
Date interval history
Highest data usage list
Last connection details
Technical Specifications
Architecture
Standard server client web architecture
Multi-tenant architecture
Probe design to collect data from remote site without VPN or behind NAT
User Management
Read-write and read-only privileges by modules
Discovery
Device Discovery
Support SNMP v1, v2c, v3 scan
Support IPv4/IPv6 address range scan
Support smart scan by neighborhood
Support discover across LAN by probe
Link Discovery
Support LLDP,  FDB based link discovery
Auto Discovery
Support periodically discovery with specific time period
Inventory Management
Support inventory and devices export
Support device grouping by labels, a device can belong to multiple labels
Monitoring
Dashboard
Support overall system and product summary for wired or wireless devices
Support customized dashboard
Sensor
Support following methods to data collection
SNMP
PING
Topology View
Support auto-topology generation
Support customized topology generation
Support devices status display
Support link status display
Support different structure of topology (tree type, start type)
Support multi-layer topology for following views
Support customized background image overlay for following views
Panel View
Support panel and LED status of switches
Support panel view with stacking switches
Status Polling
Support multiple polling methods
Ping
SNMP
Support customized polling time for each devices or by group
RF channel usage rate, RX/TX usage rate and general informations of all wireless access devices
Event & Notification
Support customized criteria or threshold to trigger the event based on following rules
Value Match
Keyword Match
Keyword Combination Match
Support customized escalation rules
Support email notification to defined users
Device Configuration
Support pre-defined template to quick config single or multiple devices
Support script dispatch with variables (such as IPv4 and IPv6, system name, etc.) defined by each devices
Firmware Upgrade
Support firmware upgrade for single or multiple devices
Config Backup / Restore
Support one-time scheduled config backup for single or multiple devices
Support periodically scheduled config backup for single or multiple devices
Support config restore by system-stored or user by user-uploaded file for single or multiple devices
Task Management
Support one-time scheduled task
Support periodically scheduled task
Advanced Report & Information
Report
Selectable file format PDF or CSV
E-mail function
Easy report interface
Radio performance retrospective reports
History Report
User
Location
Devices (AP, devices)
Management System
Connection time
Data usage
Ap information
Radio link status
Radio State Information
Channel occupancy
Connected client number
Wireless Features
RF Management and Control
Auto Output Power Control
Auto Channel
Self-healing around failed APs
Multiple SSIDs per Radio(AP)
16
Advanced Wireless Features
Band steering
L2 roaming
WIDS System
Rogue AP detection
WLAN Management
Maximum APs per Device (Controller)
500
WLAN Management Features
AP grouping
Multi-tenancy
Visualized topology
NAT pass-through
AP-Controller Connection Mode
Bridge mode
User Authentication
Guest Portal
Captive portal
Authentication Method
LDAP
Voucher
Local
POP3
RADIUS
Hotspot Features
Built-in support for voucher-based authentication Built-in hotspot manager for voucher creation and guest management
Rate limiting and bandwidth control for guest and hotspot portal
Çözümler
Sipariş Bilgisi
Görseller
D-View 71.50
Front view
İndir
Destek Merkezi
