Hızlı Arama
Ürün Özellikleri:
2-Port Gigabit PoE Extender
Genel Özellikler:
PoE + Data Ports (IN)
1 x 10/100/1000BASE-T RJ-45 port, supports half/full-duplex
PoE + Data Ports (OUT)
2 x 10/100/1000BASE-T RJ-45 ports, supports half/full-duplex
Standards
IEEE 802.3
IEEE 802.3u
IEEE 802.3ab
IEEE 802.3af
IEEE 802.3at
IEEE 802.3x Flow Control
Indicator LEDs (Per Unit)
1 x PoE In
2 x PoE Out
Solid blue: PoE connected
Blinking blue: PoE budget overload
Dimensions (L x W x H)
155 x 60 x 40 mm
Weight
154 g
Power Input
Power over Ethernet
Voltage Output**
IEEE 802.3at: 50 V to 57 V DC
IEEE 802.3af: 44 V to 57 V DC
Power Consumption
Maximum: 3.05 W
Standby: 1.61 W
Temperature
Operating: -10 to 60 °C
Storage: -40 to 85 °C
Humidity
Operating: 10% to 95% non-condensing
Storage: 5% to 95% non-condensing
Certifications
CE
FCC
LVD/CE
IC
* Maximum distance as per IEEE 802.3u specifications. Distances exceeding 100 m can be reached by linking additional DPE-302GE units.
**Voltage output is set after coordination with a PD and can be within 44 V to 57 V.
Fiziksel Özellikler
Ürünler | Destek  | Haberler  | Hakkında |
