Hızlı Arama
Ürün Özellikleri:
Gigabit PoE injector (output voltage 54V DC)
Genel Özellikler:
Fiziksel Özellikler
Hardware PoE + data (out) • Support half/full duplex • 10/100/1000BASE-T • Compliance with the IEEE 802.3 standard • Compliance with IEEE 802.3 U and • IEEE 802.3 at • Compliance with the IEEE 802.3 AF standard for • Compliance with IEEE 802.3 AB and Data (in) • Support half/full duplex • 10/100/1000BASE-T • Compliance with the IEEE 802.3 standard • Compliance with IEEE 802.3 U and • Compliance with IEEE 802.3 AB and Indicators • Blue: power • Green: connection Physical parameters Weight • 70 grams Dimensions • 109,8 x 62,2 x 24.5 mm Conditions Food • Input: 54 / 0.6 A (from external power adapter) • Maximum consumption: 32,4 W • Output: 54 / 0.6 A Temperature • Operating: 0 to 50 °C • Storage: -30 to 70 °C Humidity • Operating: 5% to 95% non-condensing • Storage: 5% to 95% non-condensing The average MTBF (hours) • 196 581 The kit • Packing • PoE-injector • Power adapter DC 54 In/0.4 A • Ethernet cable (cat 5E/direct) • Quick installation guide • Kit for wall mounting (plastic screw anchors + screws) Other • Conformity to RoHS Directive 6 • Reduced energy consumption by mode on/off Certificates EMC: • CE • FCC AND IC • RCM • Chamber - • BSMI • CCC Security: • Ul • KB • CCC • BSMI
Ürünler | Destek  | Haberler  | Hakkında |
