DWL-6600APEOL EOS
Unified Wireless Access Point 802.11n, up to 300 Mbit / s with PoE
Nereden Alınır
Tanımlama
DWL-6600AP - Universal Dual Band 802.11n Access Point with PoE for indoor use designed for network deployment in business class. Flexibility in managing and supporting data transfer at high speed, this access point provides easy integration with existing network infrastructure, which can be further expanded. An access point may be made in the housing class Plenum (DWL-6600AP/A1A) or conventional plastic housing (DWL-6600AP/A1A/PC).
High performance
DWL-6600AP provides data transfer rates of up to 300 Mbit / s at a frequency of 2.4 GHz or 5 GHz. Support for Wi-Fi Multimedia ™ (WMM) makes an ideal access point for audio, video, and voice applications. In addition, load balancing ensures maximum performance and excellent quality of service in a wireless network.
Automatic Cluster Configuration
For small businesses that require multiple access points (APs), and that lack of resources, the automatic configuration of the cluster is the ideal solution. When you install a small number of AP DWL-6600AP can be configured to perform automatic cluster.After performing an administrator configure a single access point, the same settings will be applied to other access points.Thus, a cluster can combine up to 16 access points.
Unified management
DWL-6600AP can operate in conjunction with the wireless switch and controller D-Link. In this mode, multiple access DWL-6600AP can be connected directly or indirectly to one of the switches / controllers to ensure a high level of security and wireless mobility for wireless clients.
Each DWL-6600AP is set on the switches that provide the desired wireless signals in both 2.4GHz and 5.0GGts to ensure the optimization of RF channels and power for all mobile customers.
Safety
DWL-6600AP supports the latest standards for safety of Wi-Fi, including WEP, WPA, WPA2 and 802.1X. In addition, DWL-6600AP supports up to 16 virtual access points (VAP) or up to 32 in total), which allows the administrator to assign different access rights for different groups of users. If you have enabled "Isolation station", then the access point will block the transmission of data between the wireless clients that are connected to a wireless network in the same radio frequency.Through the use of Unified Wireless D-Link switches can increase the level of security. You can easily detect unauthorized network access point, so the administrator will be able to immediately prevent a safety hazard.
Easy installation
With built-in antenna and stylish design, DWL-6600AP can be mounted on a wall or on the ceiling, and the device fits neatly in most offices. Access Point DWL-6600AP is enclosed in a housing with ventilation in accordance with the rules of fire safety.This high-speed access point supports standard 802.3af Power over Ethernet (PoE), which allows you to install the device, even in areas where power outlets are not available.
Genel Özellikler
Fiziksel Özellikler
System
• Wireless Interface: 802.11a/b/g/n (2,4 / 5 GHz)
• Interface LAN: 10/100/1000 Gigabit Ethernet
• The console port: RJ-45
• Antenna: Built-in omni-directional 2x2 MIMO antennas for 2.4 GHz and 5 GHz, 4 RP-SMA connector for external antenna
• Antenna Gain: 5 dBi for 2.4 GHz and 6 dBi for 5 GHz
• Power: IEEE 802.3af Power Over Ethernet or external power adapter
Frequency
• 802.11n: 2,4 GHz - 2.497 GHz and 4.9 GHz - 5.85 GHz
• 802.11b / g: 2,4 GHz - 2.485 GHz
• 802.11a: 5,15 GHz - 5.35 GHz and 5.725 GHz - 5.825 GHz
Data rate
• 802.11n
  6.5 Mbit / sec - 130 Mb / s (20 Mbit / s)
  6.5 Mbit / sec - 300 Mb / s (40 Mbit / s)
• 802.11a / g: 54, 48, 36, 24, 18, 12, 9 and 6 Mbit / s
• 802.11b: 11, 5.5, 2 and 1 Mbit / s
The output power of the transmitter
• 802.11a / g: 11 (+ / -2) dBm at 54, 48, 36, 24, 18, 12, 9 and 6 Mbit / s
• 802.11b: 13 (+ / -2) dBm at 11,5.5, 2 and 1 Mbit / s
• 802.11n (2,4 GGts/HT-20): 11 dBm at MCS0 / 8, MCS1 / 9, MCS2/10, MCS3/11, MCS4/12, MCS5/13, MCS6/14, MCS7/15
• 802.11n (2,4 GGts/HT-40): 11 dBm at MCS0 / 8, MCS1 / 9, MCS2/10, MCS3/11, MCS4/12, MCS5/13, MCS6/14, MCS7/15
• 802.11n (5 GGts/HT-20): 11 dBm at MCS0 / 8, MCS1 / 9, MCS2/10, MCS3/11, MCS4/12, MCS5/13, MCS6/14, MCS7/15
• 802.11n (5,0 GGts/HT-40): 11 dBm at MCS0 / 8, MCS1 / 9, MCS2/10, MCS3/11, MCS4/12, MCS5/13, MCS6/14, MCS7/15
Receiver Sensitivity
• 802.11a
  -86 (+ / -2) DBm at 6 Mbit / s
  -86 (+ / -2) DBm at 9 Mbits / s
  -84 (+ / -2) DBm at 12 Mbit / s
  -81 (+ / -2) DBm at 18 Mbit / s
  -77 (+ / -2) DBm at 24 Mbit / s
  -75 (+ / -2) DBm at 36 Mbit / s
  -68 (+ / -2) DBm at 48 Mbit / s
  -67 (+ / -2) DBm at 54 Mbit / s
• 802.11b
  -92 (+ / -2) DBm at 1 Mbit / s
  -90 (+ / -2) DBm at 2 Mbit / s
  -88 (+ / -2) DBm at 5.5 Mbit / s
  -85 (+ / -2) DBm at 11 Mbit / s
• 802.11g
  -87 (+ / -2) DBm at 6 Mbit / s
  -87 (+ / -2) DBm at 9 Mbits / s
  -85 (+ / -2) DBm at 12 Mbit / s
  -82 (+ / -2) DBm at 18 Mbit / s
  -79 (+ / -2) DBm at 24 Mbit / s
  -76 (+ / -2) DBm at 36 Mbit / s
  -71 (+ / -2) DBm at 48 Mbit / s
• 802.11n
 2.4 GGts/HT-20
  - 85dBm at MCS0 / 8
  - 82dBm at MCS1 / 9
  - 80dBm at MCS2/10
  - 77dBm at MCS3/11
  - 74dBm at MCS4/12
  - 69dBm at MCS5/13
  - 68dBm at MCS6/14
  - 65dBm at MCS7/15
 2.4 GGts/HT-40
  -82 DBm at MCS0 / 8
  -79 DBm at MCS1 / 9
  -77 DBm at MCS2/10
  -74 DBm at MCS3/11
  -71 DBm at MCS4/12
  -66 DBm at MCS5/13
  -65 DBm at MCS6/14
  -62 DBm at MCS7/15
 5.0 GGts/HT-20
  - 85dBm at MCS0 / 8
  - 79dBm at MCS1 / 9
  - 77dBm at MCS2/10
  - 74dBm at MCS3/11
  - 70dBm at MCS4/12
  - 66dBm at MCS5/13
  - 65dBm at MCS6/14
  - 64dBm at MCS7/15
5.0 GGts/HT-40
  -79 DBm at MCS0 / 8
  -76 DBm at MCS1 / 9
  -74 DBm at MCS2/10
  -71 DBm at MCS3/11
  -67 DBm at MCS4/12
  -64 DBm at MCS5/13
  -63 DBm at MCS6/14
  -62 DBm at MCS7/15
Safety
• SSID:
  + 16 SSID, 32 to the access point SSID
  + Insulation Station
• Security: WEP, Dynamic WEP, WPA Personal / Enterprise, WPA2 Personal / Enterprise
• Detection and Prevention: Classification of unauthorized access points and unauthorized
• Authentication: Filtering MAC-address, 802.1x
System control
• Web-user interface: HTTP / HTTPS
• Command line: SNMP, SSH, Telnet
Fiziksel Özellikler
Nutrition
• Power Adapter: 12V / 1A
• Power over Ethernet: 48 VDC + / - 10%
Type of housing
Plastic housing or housing class Plenum
Case Size
77,5 x 156 mm
Weight
0.5 kg
Operating temperature
0 ˚ to 40 ˚ C
Operating Humidity
From 10% to 90% non-condensing
Safety
cUL, LVD (EN60950-1), UL20432
Certifications EMI / EMC / RF
FCC Class B, CE Class B, C-tick, IC, VCCI, NCC, TELEC, Wi-Fi ®
Çözümler
Sipariş Bilgisi
Görseller
DWL-6600AP/Ax
Front view
Left side view
Вид снизу
İndir
Destek Merkezi
