Hızlı Arama
Ürün Özellikleri:
Unified Wireless Access Point 802.11n, up to 300 Mbit / s with PoE
Genel Özellikler:
Fiziksel Özellikler
System
• Wireless Interface: 802.11a/b/g/n (2,4 / 5 GHz)
• Interface LAN: 10/100/1000 Gigabit Ethernet
• The console port: RJ-45
• Antenna: Built-in omni-directional 2x2 MIMO antennas for 2.4 GHz and 5 GHz, 4 RP-SMA connector for external antenna
• Antenna Gain: 5 dBi for 2.4 GHz and 6 dBi for 5 GHz
• Power: IEEE 802.3af Power Over Ethernet or external power adapter
Frequency
• 802.11n: 2,4 GHz - 2.497 GHz and 4.9 GHz - 5.85 GHz
• 802.11b / g: 2,4 GHz - 2.485 GHz
• 802.11a: 5,15 GHz - 5.35 GHz and 5.725 GHz - 5.825 GHz
Data rate
• 802.11n
  6.5 Mbit / sec - 130 Mb / s (20 Mbit / s)
  6.5 Mbit / sec - 300 Mb / s (40 Mbit / s)
• 802.11a / g: 54, 48, 36, 24, 18, 12, 9 and 6 Mbit / s
• 802.11b: 11, 5.5, 2 and 1 Mbit / s
The output power of the transmitter
• 802.11a / g: 11 (+ / -2) dBm at 54, 48, 36, 24, 18, 12, 9 and 6 Mbit / s
• 802.11b: 13 (+ / -2) dBm at 11,5.5, 2 and 1 Mbit / s
• 802.11n (2,4 GGts/HT-20): 11 dBm at MCS0 / 8, MCS1 / 9, MCS2/10, MCS3/11, MCS4/12, MCS5/13, MCS6/14, MCS7/15
• 802.11n (2,4 GGts/HT-40): 11 dBm at MCS0 / 8, MCS1 / 9, MCS2/10, MCS3/11, MCS4/12, MCS5/13, MCS6/14, MCS7/15
• 802.11n (5 GGts/HT-20): 11 dBm at MCS0 / 8, MCS1 / 9, MCS2/10, MCS3/11, MCS4/12, MCS5/13, MCS6/14, MCS7/15
• 802.11n (5,0 GGts/HT-40): 11 dBm at MCS0 / 8, MCS1 / 9, MCS2/10, MCS3/11, MCS4/12, MCS5/13, MCS6/14, MCS7/15
Receiver Sensitivity
• 802.11a
  -86 (+ / -2) DBm at 6 Mbit / s
  -86 (+ / -2) DBm at 9 Mbits / s
  -84 (+ / -2) DBm at 12 Mbit / s
  -81 (+ / -2) DBm at 18 Mbit / s
  -77 (+ / -2) DBm at 24 Mbit / s
  -75 (+ / -2) DBm at 36 Mbit / s
  -68 (+ / -2) DBm at 48 Mbit / s
  -67 (+ / -2) DBm at 54 Mbit / s
• 802.11b
  -92 (+ / -2) DBm at 1 Mbit / s
  -90 (+ / -2) DBm at 2 Mbit / s
  -88 (+ / -2) DBm at 5.5 Mbit / s
  -85 (+ / -2) DBm at 11 Mbit / s
• 802.11g
  -87 (+ / -2) DBm at 6 Mbit / s
  -87 (+ / -2) DBm at 9 Mbits / s
  -85 (+ / -2) DBm at 12 Mbit / s
  -82 (+ / -2) DBm at 18 Mbit / s
  -79 (+ / -2) DBm at 24 Mbit / s
  -76 (+ / -2) DBm at 36 Mbit / s
  -71 (+ / -2) DBm at 48 Mbit / s
• 802.11n
 2.4 GGts/HT-20
  - 85dBm at MCS0 / 8
  - 82dBm at MCS1 / 9
  - 80dBm at MCS2/10
  - 77dBm at MCS3/11
  - 74dBm at MCS4/12
  - 69dBm at MCS5/13
  - 68dBm at MCS6/14
  - 65dBm at MCS7/15
 2.4 GGts/HT-40
  -82 DBm at MCS0 / 8
  -79 DBm at MCS1 / 9
  -77 DBm at MCS2/10
  -74 DBm at MCS3/11
  -71 DBm at MCS4/12
  -66 DBm at MCS5/13
  -65 DBm at MCS6/14
  -62 DBm at MCS7/15
 5.0 GGts/HT-20
  - 85dBm at MCS0 / 8
  - 79dBm at MCS1 / 9
  - 77dBm at MCS2/10
  - 74dBm at MCS3/11
  - 70dBm at MCS4/12
  - 66dBm at MCS5/13
  - 65dBm at MCS6/14
  - 64dBm at MCS7/15
5.0 GGts/HT-40
  -79 DBm at MCS0 / 8
  -76 DBm at MCS1 / 9
  -74 DBm at MCS2/10
  -71 DBm at MCS3/11
  -67 DBm at MCS4/12
  -64 DBm at MCS5/13
  -63 DBm at MCS6/14
  -62 DBm at MCS7/15
Safety
• SSID:
  + 16 SSID, 32 to the access point SSID
  + Insulation Station
• Security: WEP, Dynamic WEP, WPA Personal / Enterprise, WPA2 Personal / Enterprise
• Detection and Prevention: Classification of unauthorized access points and unauthorized
• Authentication: Filtering MAC-address, 802.1x
System control
• Web-user interface: HTTP / HTTPS
• Command line: SNMP, SSH, Telnet
Fiziksel Özellikler
Nutrition
• Power Adapter: 12V / 1A
• Power over Ethernet: 48 VDC + / - 10%
Type of housing
Plastic housing or housing class Plenum
Case Size
77,5 x 156 mm
Weight
0.5 kg
Operating temperature
0 ˚ to 40 ˚ C
Operating Humidity
From 10% to 90% non-condensing
Safety
cUL, LVD (EN60950-1), UL20432
Certifications EMI / EMC / RF
FCC Class B, CE Class B, C-tick, IC, VCCI, NCC, TELEC, Wi-Fi ®
Ürünler | Destek  | Haberler  | Hakkında |
