Hızlı Arama
Ürün Özellikleri:
Unified Wireless Access Point 802.11n, up to 300 Mbit / s with PoE
Tanımlama:
DWL-6600AP - Universal Dual Band 802.11n Access Point with PoE for indoor use designed for network deployment in business class. Flexibility in managing and supporting data transfer at high speed, this access point provides easy integration with existing network infrastructure, which can be further expanded. An access point may be made in the housing class Plenum (DWL-6600AP/A1A) or conventional plastic housing (DWL-6600AP/A1A/PC).
High performance
DWL-6600AP provides data transfer rates of up to 300 Mbit / s at a frequency of 2.4 GHz or 5 GHz. Support for Wi-Fi Multimedia ™ (WMM) makes an ideal access point for audio, video, and voice applications. In addition, load balancing ensures maximum performance and excellent quality of service in a wireless network.
Automatic Cluster Configuration
For small businesses that require multiple access points (APs), and that lack of resources, the automatic configuration of the cluster is the ideal solution. When you install a small number of AP DWL-6600AP can be configured to perform automatic cluster.After performing an administrator configure a single access point, the same settings will be applied to other access points.Thus, a cluster can combine up to 16 access points.
Unified management
DWL-6600AP can operate in conjunction with the wireless switch and controller D-Link. In this mode, multiple access DWL-6600AP can be connected directly or indirectly to one of the switches / controllers to ensure a high level of security and wireless mobility for wireless clients.
Each DWL-6600AP is set on the switches that provide the desired wireless signals in both 2.4GHz and 5.0GGts to ensure the optimization of RF channels and power for all mobile customers.
Safety
DWL-6600AP supports the latest standards for safety of Wi-Fi, including WEP, WPA, WPA2 and 802.1X. In addition, DWL-6600AP supports up to 16 virtual access points (VAP) or up to 32 in total), which allows the administrator to assign different access rights for different groups of users. If you have enabled "Isolation station", then the access point will block the transmission of data between the wireless clients that are connected to a wireless network in the same radio frequency.Through the use of Unified Wireless D-Link switches can increase the level of security. You can easily detect unauthorized network access point, so the administrator will be able to immediately prevent a safety hazard.
Easy installation
With built-in antenna and stylish design, DWL-6600AP can be mounted on a wall or on the ceiling, and the device fits neatly in most offices. Access Point DWL-6600AP is enclosed in a housing with ventilation in accordance with the rules of fire safety.This high-speed access point supports standard 802.3af Power over Ethernet (PoE), which allows you to install the device, even in areas where power outlets are not available.
Ürünler | Destek  | Haberler  | Hakkında |
