DNS-327LEOL EOS
Network Storage ShareCenter ™ + 2-bay hard drive and support service mydlink
Tanımlama
Network Storage ShareCenter ™ + 2-bay hard drive and support service mydlink DNS-327L is a handy solution for the file-sharing and backup of critical data by creating a personal "cloud".
Remote sharing
Network Storage ShareCenter ™ + 2-bay hard drive and support service mydlink DNS-327L is equipped with a Web-server file that lets you download documents, photos and other media files wherever you are. After setting the ShareCenter benefit from the convenient Web-based user interface to browse the list of available files.
You can also use the app mydlink Access - NAS to connect to the device and play music, view videos and photos directly on your mobile device. With the mydlink portal can easily gain remote access to media content, without complicated network configuration.
Easy Installation and Setup
Installing drives in the DNS-327L is not difficult - just remove the cover and attach the mounting disc and insert a 3.5 "SATA hard drives with up to 4TB. Click the snap to gain access to the drive bays, and then install them. Convenient USB port on the back of the ShareCenter can be used for connecting the USB-printer, uninterruptible power supply (UPS) or an external USB-drive to perform backups at the touch of a button.
When sharing the DNS-327L Cloud Router and D-Link technology can be applied Zero Configuration, which greatly simplifies the setup DNS-327L. Simply select the type of RAID, and the mechanism of Zero Configuration will perform the rest of the work.
Streaming media content using built-in media server
Back up your media files for secure storage on the ShareCenter and take advantage of built-in DLNA media server UPnP AV to stream digital media content to compatible media players such as the PlayStation ® 3, Microsoft ® Xbox 360 ™, or directly on the Smart TV . You can also get access to photos, music and videos remotely via mobile devices.
High performance and flexibility
ShareCenter supports hard drives in four different configurations (Standard, JBOD, RAID 0, RAID 1) in order to select the best of them, depending on your requirements. In Standard mode creates two separate hard disks available. JBOD combines both drives into one volume. RAID 0 combines both drives in a striped array for maximum performance when using a compound of Gigabit Ethernet. In RAID 1, the contents of one hard drive is duplicated on the other, providing maximum reliability. If one drive fails, the other will continue to operate separately as long as there is no replacement of a failed drive. DNS-327L supports hot-swappable drives, thanks to which the failed drive can be replaced easily, and then the data will be automatically copied to the new disk, allowing the array ShareCenter return to full level of protection, while maintaining the integrity of the files.
