Hızlı Arama
Ürün Özellikleri:
Network Storage ShareCenter Shadow 2-Bay Hard Drive
EOL EOS
Genel Özellikler:
Fiziksel Özellikler
Standards:
  • IEEE 802.3
  • IEEE 802.3u
  • IEEE 802.3ab
  • TCP / IP
  • CIFS / SMB
  • NFS
  • AFP
  • DHCP client
  • DDNS
  • NTP
  • FTP over SSL / TLS, FXP
  • HTTP / HTTPS
  • LLT D
  • PnP-X
  • UPnP AV
  • USB 2.0
  • Bonjour
  • WebDAV
Indicators:
  • Power
  • LAN
  • HDD 1
  • HDD 2
Ports:
  • 1 10/100/1000 Gigabit Ethernet port
  • 1 USB 2.0 port
  • Board
Supports the following types of hard drives 1 :
  • 3.5-inch internal SATA I / II drive (maximum capacity of 2 TB per disk) 2
Disk Management:
  • Four different hard drive configurations: RAID 0, RAID 1, JBOD, Standard
  • RAID migration from Non-RAID to RAID 1
  • Hard disk formatting: EXT3
  • Disk Checking
  • SMART
Downloaded file management:
  • The download via HTTP / FTP schedule
  • P2P (Peer to Peer)
Event Log Management:
  • Users Event Log Management
  • Group Event Management magazine
  • User / group quota management
  • Network Access Control
  • Disk installation techniques Management
Backup management
  • Backup from a computer to a network repository schedule
  • Local backup schedule
  • Remote backup schedule
  • Apple Time Machine Support Functions
  • Backup USB backup device
Remote access to documents:
  • AjaXplorer, WebDAV
Device Management:
  • In Internet Explorer 7 +, Mozilla Firexof 3 + or Apple Safari 4 +
  • Easy Search program
  • E-mail messages. email or SMS
  • System / FTP log
  • Yahoo! Widget
General access to the file:
  • The maximum amount of user accounts: 256
  • The maximum number of groups: 32
  • Maximum total number of folders (without downloads): 128
  • The maximum number of simultaneous connections: 64 (Samba) / 10 (FTP)
Applications (by default):
  • Uploading via FTP / HTTP
  • Remote / local backup
  • Sending via P2P
  • Web File Server
Additional packages (by default):
  • SqueezeCenter
  • Blog
  • Audio Streamer
  • AjaXplorer
  • Photo Center
Power management:
  • Energy-saving mode
  • Auto power upgrade
  • Power shutdown on schedule
  • The fan speed control
  • D-Link Green Ethernet
Physical parameters
Meals:
  • External power supply
  • 12 V DC, 4 A
Power consumption:
  • Normal: 4.21 W
  • Sleep mode: 10.45 W
Working temperature:
  • 0 º to 40 º C
Storage temperature:
  • -20 º to 70 º C
Working humidity:
  • 5% to 90% without condensation
Dimensions:
  • 104 x 198 x 132 mm
Size:
  • 1.225 kg
Supported languages ​​are:
  • Samba: Unicode
  • FTP client / iTunes Server: Unicode, Korean, Turkish, Croatian, Cyrillic (Kyrgyz Republic), Czech, Danish, Dutch, German, English, Finnish, French, Greek, Hungarian, Italian, Norwegian, Polish, Portuguese, Romanian, Russian, Simplified Chinese, Slovenian, Spanish, Swedish, Chinese tradininė Jewish
1 unit sold without hard drives. RAID 1 operation requires 2 SATA drives. For the RAID 1 function correctly, we offer the use of a single manufacturer SATA drives. Formatted disk size RAID 1 performance depends on the smaller capacity hard drive. It may not work with older generation SATA drives. Drives, tested and working with the Share Center Pulse, see the D-Link site technical support section.
2 The maximum disk capacity in the future may vary depending on changes in SATA technology.
Ürünler | Destek  | Haberler  | Hakkında |
