DFM-562ISEOL EOS
56K V.92/V.90 Software-based PCI Modem Card
Tanımlama
The DFM-562IS is a software modem card.  It plugs into a PCI expansion bus slot of a desktop PC.  It supports voice, fax and data transmission/reception.  It's a high-performance CONEXANT-based modem card,
and can be used to connect to the Internet, and for fax and voice communication.
Genel Özellikler
Çözümler
Sipariş Bilgisi
Görseller
DFM-562IS
Back view
Front view
İndir
Destek Merkezi
