DCM-202/RU/C
Cable Modem DOCSIS / EuroDOCSIS 2.0 1-port 10/100BASE-TX Fast Ethernet and USB 1.1 interface
Tanımlama
Maximum Performance
With support for the increased bandwidth TurboDoxTM Modem DCM-202 increases the download speed up to 20 times, allowing unlimited use popular Internet applications, such as file sharing, viewing and listening to audio and video streaming, Internet TV and viewing Web- pages 1 .
Compliant with DOCSIS Cable Modem DCM-202 DOCSIS / EuroDOCSIS 2.0 increases the efficiency of broadband connection, avoiding network congestion, which greatly increases the speed of the connection. With the DCM-202 users derive maximum benefit from a broadband connection invested in funds due to higher download speeds and higher productivity. DCM-202 is certified by CableLabs standard DOCSIS 2.0, which ensures its compatibility with all cable providers that support DOCSIS. DCM-202 is backward-compatible with DOCSIS 1.1/1.0.
Ethernet connection and USB DCM-202 offers a choice of connecting to a computer via Ethernet or USB. Modem Installation is effortless, the device is compatible with Windows XP/Vista/7, Mac OSX, Unix and other popular operating systems (USB connection only supports Windows XP, Vista and 7). With confidence connect to a certified cable Internet service provider using the DCM-202 and take advantage of new broadband connection to the Internet. 1 Speed ​​may vary depending on the cable provider of Internet services. For more information, please contact your provider.
Genel Özellikler
Çözümler
Sipariş Bilgisi
Görseller
DCM-202/RU/C
Front view
İndir
Destek Merkezi
