DKVM-4U
4-Port USB KVM Switch
Nereden Alınır
Tanımlama
The D-Link DKVM-4U 4-port USB KVM switch allows you to manage up to four computers with one monitor, one keyboard and one mouse. The DKVM-4U requires no driver installation and no external power adapter connection. This KVM switch supports hot-plugging - you don't need to turn your computers off before installing the device. The DKVM-4U allows you to switch between computers quickly and easily using the buttons located on the top panel or keyboard hot keys. The DKVM-4U supports autoscan mode, which provides automatic switching to the next PC after the scan interval expires.
Genel Özellikler
Hardware
Ports for connecting KVM cables
• 4 VGA ports
Ports for connecting management console
• Monitor (local): VGA
• Keyboard (local): USB Type-A
• Mouse (local): USB Type-A
Port for connecting USB-disk
• USB Type-A
KVM cable connectors for connecting PC
• Video: 15-pin HDB connector (VGA)
• Keyboard/Mouse: USB Type-A connector
LEDs
• 4 port LEDs for connected PCs
Buttons
• 4 port switching buttons
Enclosure
• Plastic
Connected PCs
• Up to 4
Autoscan mode
• Yes
Switching between PCs
• Switching buttons on the top panel
• Hot keys
Sound notification of switching
• Yes
Max. resolution
• 2048x1536
Physical Parameters
Dimensions (L x W x H)
• 100 x 65 x 27 mm
Weight
• 725 g
Environmental Conditions
Power Supply
• From USB port on PC (no external power adapter required)
Temperature
• Operating: 0 to 50 °C
• Storage: -20 to 60 °C
Humidity
• 0% to 80% non-condensing
NOTE! The KVM cables of hardware version B are compatible only with the DKVM-4U KVM switch of hardware version C.
Fiziksel Özellikler
Çözümler
Sipariş Bilgisi
DKVM-4U  4-Port USB KVM Switch
Görseller
DKVM-4U
Left side view
View from the right
Вид сверху
Front view
İndir
Destek Merkezi
