Hızlı Arama
Ürün Özellikleri:
1000Base-SX Multi-Mode SFP transceiver (up to 550 m)
Proje
Genel Özellikler:
Features
Standard
• IEEE 802.3z 1000Base-SX
Wavelength
• 850 nm
Data Rate
• 1.25 Gbps
Connector
• Duplex LC
Fiber Type
• 50/125 um Multi-mode Fiber (up to 550 m)
• 62.5/125 um Multi-mode Fiber (up to 300 m)
Maximum Fiber Cable Length
• 550 m
Transmit Power Range
• -3 to -8 dBm
Receive Power Range
• -3 to -22 dBm
Sensitivity
• -22 dBm
Features
• Hot Pluggable
• MSA Compliant
• RoHS Compliant
Physical Parameters
Power Support
• 3.3 V
Supply Current
• 300 mA
Power Budget
• 14 to 19 dB
Heat Generated
• 1.782 kJ/h
MTBF (hours)
• 224 167
Temperature
• Operating: -40 to 85 В°C
• Storage: -40 to 85 В°C
Humidity
• Operating: 5% to 95%
• Storage: 5% to 95%
Dimensions
• 55.4 mm x 13.7 mm x 8.5 mm
Weight
• 20 g
EMI
• CE
• FCC
• VCCI
Safety
• LVD
• EN 60825-1
• EN 60825-2
Fiziksel Özellikler
Ürünler | Destek  | Haberler  | Hakkında |
