Hızlı Arama
Ürün Özellikleri:
20 10/100/1000BASE-T PoE ports + 4 Combo 10/100/1000BASE-T PoE/SFP ports + 4 10 GbE SFP+ ports L3 Stackable Managed Switch
Genel Özellikler:
Number of Ports
• 44 x 10/100/1000Base-T PoE ports
• 4 x Combo 10/100/1000Base-T PoE/SFP ports
• 4 x 10 GbE SFP+ ports
Console Port
• RJ-45 and Mini USB console ports for out-of-band CLI management
Management Port
• 10/100/1000Base-T RJ-45 Ethernet for out-of-band IP management
Alarm Port
• RJ-45 port
USB Port
• USB 2.0 Type A port
Performance
• Switching Capacity: 176 Gbps
• Packet Forwarding Rate: 130.95 Mpps
• Packet Buffer: 4 MBytes
• MAC Address Table: 68K entries*
• IPv4 Routing Table: 16K entries
• IPv6 Routing Table: 7K entries
• IPv4 Forwarding Table: 32K entries*
• IPv6 Forwarding Table: 16K entries*
• Jumbo Frame Size: 12 KBytes
PoE Standards
• IEEE 802.3af/at
PoE Power Budget
• 370 W (740 W with DPS-700 RPS redundant power supply**)
Standard Image (SI) Software Features
Stackability
• Physical Stacking
  - Up to 80 Gbps stacking bandwidth
  - Up to 9 switches in a stack
  - Ring/chain topology support
• Virtual Stacking/Clustering of up to 32 units
  - Supports D-Link Single IP Management
  - Up to 20 Gbps stacking bandwidth
L2 Features
• MAC Address Table: up to 68K entries*
• Flow Control
  - 802.3x Flow Control when using Full Duplex
  - HOL Blocking Prevention
• Spanning Tree Protocol
  - 802.1D STP
  - 802.1w RSTP
  - 802.1s MSTP
  - Root Guard
  - Loop Guard
• Jumbo Frame: up to 12 KBytes
• 802.1AX Link Aggregation
  - Max. 32 groups per device, 8 ports per group
• ERPS (Ethernet Ring Protection Switching) version 2
• Port Mirroring
  - Supports One-to-One, Many-to-One,
  - Supports Mirroring for Tx/Rx/Both
  - Supports 4 mirroring groups
• Flow Mirroring
  - Supports Mirroring for Rx
• VLAN Mirroring
• RSPAN
• L2 Protocol Tunneling
• Multi-Chassis Link Aggregation Group (MLAG)***
VLAN
• 802.1Q
• 802.1v Protocol-based VLAN
• Double VLAN (Q-in-Q)
  - Port-based Q-in-Q
  - Selective Q-in-Q
• Port-based VLAN
• MAC-based VLAN
• Subnet-based VLAN
• Private VLAN
• VLAN Group
  - Max. 4K VLAN groups
  - Max. 4094 VIDs
• Multicast VLAN (ISM VLAN for IPv4/IPv6)
• Voice VLAN
• Auto Surveillance VLAN
• VLAN Trunking
• GVRP: Up to 4K dynamic VLANs
• Asymmetric VLAN
L2 Multicast
• MLD Snooping
  - MLD v1/v2 Snooping
  - Supports up to 4K MLD groups
  - Host-based MLD Snooping Fast Leave
  - Supports 64 static MLD groups
  - MLD Snooping Querier
  - Per VLAN MLD Snooping
  - MLD Proxy Reporting
• IGMP Snooping
  - IGMP v1/v2/v3
  - Supports up to 8K MLD groups*
  - Supports 64 static IGMP groups*
  - Per VLAN IGMP Snooping
  - IGMP Snooping Querier
  - Host-based IGMP Snooping Fast Leave
• PIM Snooping
L3 Features
• IPv4 ARP/IPv6 ND: support up to 32K/16K*
  - 512 Static ARP
• Gratuitous ARP
• IP Interface
  - Supports 256 interfaces
• Loopback Interface
• Proxy ARP
  - Support local ARP proxy
• IPv6 Tunneling
  - Static
  - ISATAP
  - GRE
  - 6to4
• VRRP v2/v3
• IP Helper
L3 Routing
• Supports 16K hardware routing entries shared by IPv4/IPv6
  - 1 entry consumed by each IPv4 route
  - 2 entries consumed by each IPv6 route
• Supports up to 32K hardware L3 forwarding entries shared by IPv4/IPv6*
• Static Route
  - Max. 512 IPv4 entries
  - Max. 256 IPv6 entries
• IPv4/IPv6 Default Route
• PBR (Policy-based Route)
• Null Route
• Route Preference
• Route Redistribution
• Graceful Restart (GR) Helper
• BFD (Bidirectional Forwarding Detection)
  - IPv4/v6 Static Route
  - RIP
  - VRRP
• RIPv1/v2/ng
L3 Multicast
• IGMP/MLD Filtering
QoS (Quality of Service)
• 802.1p
• 8 queues per port
• Queue Handling
  - Strict Priority (SP)
  - Weighted Round Robin (WRR)
  - Strict + WRR
  - Weighted Deficit Round Robin (WDRR)
• Congestion Control
• Weighted Random Early Detection (WRED)
• 802.1Qbb Priority-based Flow Control (PFC) for 10 GbE port
• Bandwidth Control
  - Port-based (Ingress/Egress, min. granularity 8 Kb/s)
  - Flow-based (Ingress/Egress, min. granularity 8 Kb/s)
  - Per queue bandwidth control (min. granularity 8 Kb/s)
• Policy Map
  - Remark 802.1p priority
  - Remark IP precedence/DSCP
  - Time based QoS
• CoS based on:
  - Switch Port
  - Inner/ outer 802.1p Priority
  - Inner/ outer VID
  - MAC address
  - Ether Type
  - IP address
  - ToS/IP Preference
  - DSCP
  - Protocol Type
  - TCP/UDP port
  - IPv6 Traffic Class
  - IPv6 Flow Label
• Three Color Marker
  - trTCM
  - srTCM
ACL (Access Control List)
• ACL based on:
  - 802.1p priority
  - VID
  - MAC address
  - EtherType
  - LLC
  - VLAN
  - IP address
  - IP preference/ToS
  - DSCP mask
  - Protocol type
  - TCP/UDP port number
  - IPv6 Flow Label
• Max. ACL entries:
  - Ingress (hardware entries): 4K
  - Egress (hardware entries): 1K
  - VLAN Access Map Numbers: 3K
• Time-based ACL
Green
• Energy Effeciency Ethernet (EEE)
• Power Saving By Link Status
• Power Saving By Cable Length
• Power Saving By LED Shut-Off
• Power Saving By Port Shut-Off
• Power Saving By System Hibernation
• Time-based PoE
Security
• Port Security
  - Supports up to 12K MAC addresses per port/VLAN/system
• Broadcast/Multicast/Unicast Storm Control
• D-Link Safeguard Engine
• DHCP Server Screening
• Dynamic ARP Inspection
• IP Source Guard
• DHCP Snooping
• IPv6 Snooping
• Dynamic ARP Inspection (DAI)
• DHCPv6 Guard
• IPv6 Route Advertisement (RA) Guard
• IPv6 ND Inspection
• Duplicate Address Detection (DAD)
• ARP Spoofing Prevention
  - Max. 64 entries
• L3 Control Packet Filtering
• Unicast Reverse Path Forwarding (URPF)
• Traffic Segmentation
• SSL
  - Supports TLS 1.0/1.1
  - Supports IPv4/IPv6 access
• SSH
  - Supports SSH v2
• BPDU Attack Prevention
• DOS Attack Prevention
• NetBIOS/NetBEUI filtering
AAA
• 802.1X Authentication
  - Supports Port/Host-based access control
  - Identity-driven Policy Assignment
  - Dynamic VLAN Assignment
  - Bandwidth Control Assignment
  - ACL Assignment
• Web-based Access Control (WAC)
  - ACL Assignment
  - Support IPv4/IPv6 access
  - Support HTTPS
• Compound Authentication
• MAC-based Access Control (MAC)
  - ACL Assignment
• Guest VLAN
• MicrosoftВ® NAP
  - Support 802.1X NAP
  - Support DHCP NAP
• Privilege Level for Management Access
• RAIDUS and TACACS+ Authentication
• Authentication Database Failover
• RADIUS/TACACS+ Accounting
OAM (Operations, Administration,and Maintenance)
• Cable Diagnostics
• 802.3ah Ethernet Link OAM
• D-Link Unidirectional Link Detection (DULD)
• Dying gasp
• Y.1731 OAM
• Optical Transceiver Digital Diagnostic Monitoring (DDM)
Management
• NTPv3/v4
• Precision Time Protocol (PTP)
• Web-based GUI
  - Support SSL (HTTPS)
• Command Line Interface (CLI)
• Telnet Server for IPv4/IPv6 access
• Telnet Client for IPv4/IPv6
• SNMP
  - Support v1/v2c/v3
• SNMP Trap
• TFTP Client for IPv4/IPv6
• FTP Client for IPv4/IPv6
• IPv4 SFTP Server
• RCP
• System Log for IPv4/IPv6 Syslog Server
• SMTP
• RMONv1
  - Supports 1,2,3,9 groups
• RMONv2
  - Supports ProbeConfig group
• Command Logging
• LLDP/LLDP-MED
• D-Link Discover Protocol (DDP)
• DHCP Client option 12
• DHCP Auto-configuration
• DHCP Auto-image
• DHCP Relay option 60/61/62/18/37/125
• DHCP/DHCPv6 Local Relay
• DHCP Server
  - Support IPv4/IPv6 address assignment
• DHCPv6 Prefix Delegation (PD)
• Multiple Images/ Multiple Configurations
• DNS Relay for IPv4/IPv6
• DNS Client for IPv4/IPv6
• Debug Command
• Password Recovery/ Encryption
• Ping/ Traceroute for IPv4/IPv6
• MicrosoftВ® Network Load Balancing (NLB)
• Switch Resource Management (SRM)
• sFlow
• D-Link License Management System (DLMS)
• PD Alive
Additional Enhanced Image (EI) Features
VLAN
• Super VLAN
L3 Routing
• BGP
  - BGPv4/v4+
  - 4bytes AS
  - Text/MD5 for BGPv4
• VRF-Lite
  - IPv4 Static Route
  - RIPv1/v2
  - OSPFv2
  - BGPv4
• Bidirectional Forwarding Detection (BFD) for OSPF
• OSPF
  - OSPF v2/v3
  - OSPF passive interface
  - Stub/NSSA area
  - OSPF equal cost route
  - Text/MD5 for OSPFv2
L3 Multicast
• IGMPv1/v2/v3
• MLDv1/v2
• IGMP/MLD Proxy
• DVMRPv3
• PIM SDM (Sparse-Dense Mode)/SSM
• PIM-SM/DM for IPv4/IPv6
• SSM Mapping for IPv4/IPv6
• Multicast Source Discovery Protocol (MSDP)
Additional MPLS Image (MI) Features
L3 Routing
• IS-IS v4/v6
MPLS
• Label Distribution Protocol (LDP)
• PHP (Penultimate hop popping )
• Virtual Private Wire Service (VPWS)
• Virtual Private LAN Service (VPLS)
• BGP/MPLS VPN
• Multiprotocol extensions for BGP4
• Virtual Routing Forwarding (VRF)
• LSP/VCCV/MPLS Ping/Traceroute
MIB/IETF Standards
• RFC1065, RFC1066, RFC1155, RFC1156, RFC2578 MIB Structure
• RFC1213 MIBII
• RFC1493, RFC4188 Bridge MIB
• RFC1157, RFC2571, RFC2572, RFC2573, RFC2574, RFC2575, RFC2576 SNMP MIB
• RFC1442, RFC1901, RFC1902, RFC1903, RFC1904, RFC1905, RFC1906, RFC1907, RFC1908, RFC2578, RFC3418, RFC3636 SNMPv2 MIB
• RFC271, RFC1757, RFC2819 RMON MIB
• RFC2021 RMONv2 MIB
• RFC1398, RFC1643, RFC1650, RFC2358, RFC2665, RFC3635 Ether-like MIB
• RFC2668 802.3 MAU MIB
• RFC2674, RFC4363 802.1p MIB
• Interface Group MIB
• RFC4022 MIB for TCP
• RFC4113 MIB for UDP
• RFC2925 Ping & TRACEROUTE MIB
• TFTP uploads and downloads (D-Link MIB)
• Trap MIB (D-Link MIB)
• RFC4293 IPv6 MIB
• RFC4293 ICMPv6 MIB
• Entity MIB
• RIPv2 MIB
• OSPF MIB
• IPv4 Multicast Routing MIB
• PIM MIB for IPv4
• IP Forwarding Table MIB
• RFC4293 IPv6 SNMP Mgmt Interface MIB
• DDM MIB (D-Link MIB)
• Private MIB
• MIB for D-Link Zone Defense
• DDP MIB
• LLDP-MED MIB
• RFC791 IP
• RFC768 UDP
• RFC793 TCP
• RFC792 ICMPv4
• RFC2463, RFC4443 ICMPv6
• RFC826 ARP
• RFC1338, RFC1519 CIDR
• RFC2474, RFC3168, RFC3260 Definition of the DS Field in the IPv4 and IPv6 Headers
• RFC1321, RFC2284, RFC2865, RFC2716, RFC1759, RFC3580, RFC3748 Extensible Authentication Protocol (EAP)
• RFC2571 SNMP Framework
• RFC2572 SNMP Message Processing and Dispatching
• RFC2573 SNMP Applications
• RFC2574 User-based Security Model for SNMPv3
• RFC1981 Path MTU Discovery for IPv6
• RFC2460 IPv6
• RFC2461, RFC4861 Neighbor Discovery for IPv6
• RFC2462, RFC4862 IPv6 Stateless Address Auto-configuration
• RFC2767 Dual Stack Hosts using the ‘Bump-In-the-Stack’ Technology
• RFC3513, RFC4291 IPv6 Addressing Architecture
• RFC2893, RFC4213 IPv4/IPv6 dual stack function
• RFC3484 Default Address Selection for Internet Protocol version 6
• PoE MIB
• RFC3621 Power Ethernet MIB
Physical
MTBF
• 199,929.76 hours
Acoustics
• 51.9 dB(A)
Heat Dissipation
• 1653.85 BTU/h
Power Input
• 100 to 240 VAC 50/60 Hz
Maximum Power Consumption
• PoE off: 54.1 W
• PoE on: 485 W
Standby Power Consumption
• 44.6 W
Dimensions
• 441 x 380 x 44 mm
Weight
• 6.3 kg
Ventilation
• 4 x smart fans****
Operating Temperature
• -5 to 50 В°C
Storage Temperature
• -40 to 70 В°C
Operating Humidity
• 10% to 95% RH
Storage Humidity
• 5% to 95% RH
Surge Protection
• 6 kV surge protection on all Ethernet access ports
Safety Certifications
• cUL, CB, CE, CCC, BSMI
EMI/EMC
• CE, FCC Class A, C-Tick, VCCI, BSMI, CCC
* Based on maximum value of Switch Resource Management (SRM).
** DPS-700 is not included in the package contents.
*** Supported in firmware revision R2.10.
**** By default, the fan speed is low. When the temperature inside the chassis exceeds 37 В°C, the fans switch to high speed. When the temperature in the chassis reaches between 22 В°C to 27 В°C, the fans switch to medium speed. When the temperature inside the chassis drops below 22 В°C, the fans switch to low speed.
Fiziksel Özellikler
Ürünler | Destek  | Haberler  | Hakkında |
