Hızlı Arama
Ürün Özellikleri:
Managed Layer 2 switch with 24 10/100/1000Base-T ports and 4 10GBase-X SFP+ PoE (370watt)
Genel Özellikler:
Fiziksel Özellikler
Hardware
Interfaces
• 24 ports 10/1001000Base-T PoE
• 4 ports 10GBase-X SFP+
• Auto MDI/MDIX
Indicators
• Power (per device)
• Redundant Power Supply (RPS) (per device)
• Console (per device)
• Link/Activity/Speed (per port)
Conseole Port
• RJ-45
Network Cables
• UTP category 5, 5e cable (maximum 100m); EIA/TIA-568 100-Ohm STP (100 m max.)
Performance
Switch Fabric
•128 Gbps
The maximum transmission speed of packets
• 95,24 Mpps
Transmission method
• Store-and-forward
The MAC address table
• 16K entries
Update MAC addresses
up To 512 static entries of MAC addresses
Buffer
• 1,5 МB
Flash memory
• 32 МB
Software
Standards and functions
• IEEE802.3
• IEEE802.3u
• IEEE802.3ab
• IEEE802.3az
• IEEE802.3z
Stacking
Virtual stacking
- D-Link Single IP Management
- Up to 32 devices, United in a virtual stack
Layer 2 features
Standards and functions • IEEE802.3
• IEEE802.3u
• IEEE802.3ab
• IEEE802.3az
• IEEE802.3z
• Flow control IEEE 802.3 x
Stacking • Virtual stacking
Layer 2 features • table MAC-addresses: 16K
• Flow control
- Flow control 802.3 x
- HOL blocking prevention
- Back pressure
• Jumbo-size frames up to 9K
• Spanning Tree Protocols
- 802.1 D STP
- 802.1 w RSTP
- 802.1 s MSTP
- BPDU filtering
- Root Restriction
• Detection loops Loopback detection
• Link aggregation
- Compatible with 802.1 AX and 802.3 ad
• Port mirroring
- Support group 1 mirroring
- Modes: One-to-One, Many-to-One, Flow-based (ACL)
• Ethernet Ring Protection Switching (ERPS)
Multicast layer 2
• IGMP Snooping
- IGMP v1/v2 Snooping, v3 awareness
- Support for 1024 groups
- IGMP Snooping Fast Leave port-based/host
- Report Suppression
Authentication IGMP
- Filtering IGMP
• MLD Snooping
- MLD v1, MLD v2 awareness
- MLD snooping Fast Leave port-based/host
VLAN
• Group VLAN
- Max. 4094 VLAN
VLAN port-based
VLAN based on MAC addresses
• 802.1 Q Tagged VLAN
• GVRP
- Max. 255 dynamic VLAN
• 802.1 v Protocol VLAN
• Double VLAN (Q-in-Q)
- Q-in-Q port-based
• ISM VLAN
• VLAN Translation
• VLAN Trunking
Functions of level 3
• Max. 1024 ARP entries
- Supports 255 static ARP entries
• Supports Gratuitous ARP
• 16 IP interfaces
• A default route
• Static маршрут1
- Support 64 static routes IPv4
- Support for 32 static routes IPv6
Quality of service (QoS)
• CoS based on:
- Switch port
- Priority queue for 802.1 p
- VLAN ID
- MAC addresses
- Ether Type
- IPv4/IPv6 addresses
- DSCP
- ToS
- Protocol type
- TCP/UDP port
- Class of IPv6 traffic
- IPv6 flow label
- Content package, user-defined
• Bandwidth management
- Port-based (incoming, in increments up to 64 Kbit/s)
Based on the flow (incoming, in increments up to 64 Kbit/s)
- For output queue (in increments up to 64 Kbit/s)
• Processing queues
- Strict Priority Queue (SPQ)
- Weighted Round Robin (WRR)
• QoS on a schedule
• Three color marker
- CIR/PIR min. step up to 8 Kbit/s
- Two Rate Three Color Marker (trTCM), CBS/PBS
- Single Rate Three Color Marker (srTCM), CBS/EBS
• 8 output queues
The access control lists (ACL)
• ACL on the basis of
- Switch port
- The 802.1 p priority
- VLAN ID
- MAC addresses
- Ether type
- IPv4/v6-address
- IPv6 flow label
- DSCP
- ToS
- Protocol type
- Port number TCP/UDP
• Up to 1024 access rules for inbound traffic
• ACL schedule
• Statistics ACL
• Filtering CPU interface
AAA
• 802.1 X
- Access control port-based
- Access control host-based
- Dynamic VLAN assignment
• Access control based on MAC addresses
• Microsoft® NAP (IPv4)
• Guest VLAN
• RADIUS (IPv4)
• TACACS (IPv4)
• TACACS+ (for IPv4)
• XTACACS+ (IPv4)
• Trusted Host
• Accounting RADIUS
• 4 level user account
Security
• SSH v1/v2
• SSL v1/v2/v3
• Port Security
- Up to 64 MAC-addresses per port
• Protection from a broadcast/multicast/unicast storm
• IP-MAC-Port Binding (IMPB)
- Checking the ARP-packets
- Checking the IP-packets
- DHCP Snooping
- DHCPv6 Snooping1
- DHCPv6 Guard1
- IPv6 Route Advertisement (RA) Guard1
- IPv6 ND Snooping1
- IPv6 ND Inspection1
• Segmentation of traffic
• D-Link Safeguard Engine
• L3 Control Packet Filtering
• Filtering NetBIOS/NetBEUI
• DHCP Server Screening
• Filtering DHCP clients
• The prevention of ARP Spoofing
• Protection against attacks BPDU
• Prevention of DoS attacks
OAM
Cable Diagnostics
• 802.3 ah Ethernet Link OAM
• Dying Gasp
• 802.1 ag Connectivity Fault Management (CFM)
Management
• Web GUI (supports IPv4/IPv6)
• Command line interface (CLI)
• Telnet server/client (supports IPv4)
• TFTP/FTP-client (support IPv4)
• ZModem
• Logging of input commands
• IPv6 Neighbor Discovery
• SNMP v1/v2c/v3 (supports IPv4)
• SNMP Traps
• System log
- Max. number of entries in the log: 10 000
• SMTP (IPv4)
• RMON v1:
- Support for groups 1, 2, 3, 9
• RMON v2:
- Support Probe Config group
• 802.1 AB LLDP
- LLDP-MED
• BootP/DHCP-client (support IPv4)
• Automatically configure DHCP1
• DHCP Relay (support IPv4)
- DHCP Relay Option 60, 61 and 82
- DHCP Client Option 12
• Adding a tag PPPoE Circuit-ID1
• Supports multiple copies of SOFTWARE (Multiple Images)
• Supports multiple copies of configuration (Multiple Configurations)
• Flash file system
• Monitoring CPU
• Monitor memory
• SNTP (IPv4)
• Debugging commands
• Password recovery
• Password encryption
• Ping
• Traceroute
• Microsoft® NLB (network load Balancing) (support IPv4)
• Zero Touch Provisioning (ZTP)1
• sFlow1
• D-Link Network Assistant1
• Supports Real Time Clock (RTC)
Standarts MIB
• RFC1065, RFC1066, RFC1155, RFC1156, RFC2578
• RFC1212
• RFC1213
• RFC1215
• RFC1493, RFC4188
• RFC1157, RFC2571, RFC2572, RFC2573, RFC2574, RFC2575, RFC2576
• RFC1442, RFC1901, RFC1902, RFC1903, RFC1904, RFC1905, RFC1906, RFC1907, RFC1908, RFC2578, RFC3418, RFC3636
• RFC271, RFC1757, RFC2819
• RFC2021
• RFC1398, RFC1643, RFC1650, RFC2358, RFC2665, RFC3635
• RFC2668
• RFC2674, RFC4363
• RFC2618
• RFC4022
• RFC4113
• RFC3298
• RFC2620
• RFC2925
• RFC2465
• RFC2466
• RFC4293
• RFC3289
Physical parameters
Dimensions
• 280 x 140 x 44 mm
Weight
• 1,42 kg
Conditions
MTBF (hours)
• 762 952
Heat Dissipaiton
• 53,229 BTU/h
Power
100 to 240 VAC, 50~60 Hz
Max. power consumption
• 15,6 W
Power consumption in standby mode
• 9,8 W/In 100
• To 10.5 W/240 V
Ventilation system
• Passive
The static protection
• All Ethernet ports support the standard IEC61000-4-5 built-in protection against static electricity (up to 6 kV)
Temperature
• Operating: -5 to 50 °C
• Storage: -20 to 70 °C
Humidity
• operating: 0% to 95% non-condensing
• Storage: 0% to 95% non-condensing
The Kit
• DGS-1510-20L/ME
• 2 mounting bracket for installation in 19-inch rack
• Set of screws (8 PCs.) and rubber feet (4 PCs.)
• Connector for connecting to a backup power source
• Power cable
• Clamp for power cable
• Console cable
• Quick installation guide
• Setup CD-ROM
• Sticker with serial number
Other
EMI
• CE, FCC, C-Tick, VCCI, BSMI
Security
• cUL, CB
Ürünler | Destek  | Haberler  | Hakkında |
