DGS-1510-28L/MEEOL
Managed Layer 2 switch with 24 10/100/1000Base-T ports and 4 1000Base-X SFP
Nereden Alınır
Tanımlama
Switch DGS-1510-28 L/me is the ideal solution for use in the networks of metro Ethernet. The switch features 24 10/100/1000BASE-T ports and 4 1000BASE-x SFP port. Protection against static electricity ensures resilience against unexpected electrical spikes, while a full Suite of security features and authentication protects the network from internal and external threats. Reliability All Ethernet ports of switch a DGS-1510-28 L/me has built-in protection against static electricity to 6 kV, which allows to protect the device from power surges. In case of interruption of power supply in the switch has an additional connector for connecting redundant power supply DPS-500A/DPS-500DC or power source DC voltage of 12 V. the Switch also supports Ethernet ring protection switching (ERPs, ITU-T G. 8032), whereby the recovery time after a failure of the ring within 50 milliseconds. In addition, the switch supports the functionality of the aggregation port based 802.1 ax, which enables you to combine multiple ports into a group, increasing bandwidth and redundancy for higher availability connection to ensure smooth operation and load balancing between multiple network devices. Service Triple Play The switch DGS-1510-28 L/me implemented a wide range of functions multicast level 2, including IGMP/MLD snooping, fast leave, and filtering. Support of this functionality provides the ability to work with IPTV-services, which are gaining popularity every year and are in great demand in the market. Application of functions of IGMP/mld snooping host-based enables the connection of multiple IPTV-subscribers to one network interface. Profiles, ISM VLAN allow users to quickly and easily assign or replace the pre-defined port settings for the subscription. Supports IGMP authentication, which can prevent rogue IPTV subscriptions by authenticating set top boxes. The quality of service Switch DGS-1510-28 L/me supports advanced functionality QoS (quality of service) to provide quality service to triple play. Packet classification can be based on various header fields or user-defined packet content to help administrators prioritize network traffic. Using the bandwidth management providers to determine the level of bandwidth of incoming/outgoing channel for each port with granularity down to 64 Kbps. Easy maintenance, efficient Troubleshooting Implemented in the switch to support the extended functionality of OAM (operation, administration and management) allows to considerably simplify the maintenance, finding and Troubleshooting. Using cable diagnostics you can remotely monitor the status of the network Ethernet cable and determine the location of a malfunction that allows the provider to reduce the cost of maintenance of equipment. Function connectivity fault management (CFM, IEEE 802.1 AG) is designed to monitor, search and Troubleshooting in Ethernet networks, allowing the service providers to perform a connection test, isolate problematic segments of the network and identify the users of such segments. Security and authentication The switch DGS-1510-28 L/I provides advanced functionality authentication user/device, including 802.1 x, access control based on MAC addresses (WT). The Mac Features allow network administrators to perform user authentication/device and manage the security of your network without having to install client software, which is very important, if installation on a customer's equipment is not possible. The authentication node provides the option to finely control access by each device in the network. For integration with billing systems and services supports radius. Provided in the switch DGS-1510-28 L/I function IP-Mac-port binding (IMPB) provides strong binding to addresses and interfaces, and to prevent ARP Spoofing – network protection against attacks such as man in the middle and the ARP Spoofing.
Genel Özellikler
Fiziksel Özellikler
Hardware
Interfaces
• 24 ports 10/100/1000Base-T
• 4 ports 1000Base-X SFP
• Auto MDI/MDIX
Indicators
• Power (per device)
• Redundant Power Supply (RPS) (per device)
• Console (per device)
• Link/Activity/Speed (per port)
Conseole Port
• RJ-45
Network Cables
• UTP category 5, 5e cable (maximum 100m); EIA/TIA-568 100-Ohm STP (100 m max.)
Performance
Switch Fabric
•56 Gbps
The maximum transmission speed of packets
• 48,95Mpps
Transmission method
• Store-and-forward
The MAC address table
• 16K entries
Update MAC addresses
up To 512 static entries of MAC addresses
Buffer
• 1,5 МB
Flash memory
• 32 МB
Software
Standards and functions
• IEEE802.3
• IEEE802.3u
• IEEE802.3ab
• IEEE802.3az
• IEEE802.3z
Stacking
Virtual stacking
- D-Link Single IP Management
- Up to 32 devices, United in a virtual stack
Layer 2 features
Standards and functions • IEEE802.3
• IEEE802.3u
• IEEE802.3ab
• IEEE802.3az
• IEEE802.3z
• Flow control IEEE 802.3 x
Stacking • Virtual stacking
Layer 2 features • table MAC-addresses: 16K
• Flow control
- Flow control 802.3 x
- HOL blocking prevention
- Back pressure
• Jumbo-size frames up to 9K
• Spanning Tree Protocols
- 802.1 D STP
- 802.1 w RSTP
- 802.1 s MSTP
- BPDU filtering
- Root Restriction
• Detection loops Loopback detection
• Link aggregation
- Compatible with 802.1 AX and 802.3 ad
• Port mirroring
- Support group 1 mirroring
- Modes: One-to-One, Many-to-One, Flow-based (ACL)
• Ethernet Ring Protection Switching (ERPS)
Multicast layer 2
• IGMP Snooping
- IGMP v1/v2 Snooping, v3 awareness
- Support for 1024 groups
- IGMP Snooping Fast Leave port-based/host
- Report Suppression
Authentication IGMP
- Filtering IGMP
• MLD Snooping
- MLD v1, MLD v2 awareness
- MLD snooping Fast Leave port-based/host
VLAN
• Group VLAN
- Max. 4094 VLAN
VLAN port-based
VLAN based on MAC addresses
• 802.1 Q Tagged VLAN
• GVRP
- Max. 255 dynamic VLAN
• 802.1 v Protocol VLAN
• Double VLAN (Q-in-Q)
- Q-in-Q port-based
• ISM VLAN
• VLAN Translation
• VLAN Trunking
Functions of level 3
• Max. 1024 ARP entries
- Supports 255 static ARP entries
• Supports Gratuitous ARP
• 16 IP interfaces
• A default route
• Static маршрут1
- Support 64 static routes IPv4
- Support for 32 static routes IPv6
Quality of service (QoS)
• CoS based on:
- Switch port
- Priority queue for 802.1 p
- VLAN ID
- MAC addresses
- Ether Type
- IPv4/IPv6 addresses
- DSCP
- ToS
- Protocol type
- TCP/UDP port
- Class of IPv6 traffic
- IPv6 flow label
- Content package, user-defined
• Bandwidth management
- Port-based (incoming, in increments up to 64 Kbit/s)
Based on the flow (incoming, in increments up to 64 Kbit/s)
- For output queue (in increments up to 64 Kbit/s)
• Processing queues
- Strict Priority Queue (SPQ)
- Weighted Round Robin (WRR)
• QoS on a schedule
• Three color marker
- CIR/PIR min. step up to 8 Kbit/s
- Two Rate Three Color Marker (trTCM), CBS/PBS
- Single Rate Three Color Marker (srTCM), CBS/EBS
• 8 output queues
The access control lists (ACL)
• ACL on the basis of
- Switch port
- The 802.1 p priority
- VLAN ID
- MAC addresses
- Ether type
- IPv4/v6-address
- IPv6 flow label
- DSCP
- ToS
- Protocol type
- Port number TCP/UDP
• Up to 1024 access rules for inbound traffic
• ACL schedule
• Statistics ACL
• Filtering CPU interface
AAA
• 802.1 X
- Access control port-based
- Access control host-based
- Dynamic VLAN assignment
• Access control based on MAC addresses
• Microsoft® NAP (IPv4)
• Guest VLAN
• RADIUS (IPv4)
• TACACS (IPv4)
• TACACS+ (for IPv4)
• XTACACS+ (IPv4)
• Trusted Host
• Accounting RADIUS
• 4 level user account
Security
• SSH v1/v2
• SSL v1/v2/v3
• Port Security
- Up to 64 MAC-addresses per port
• Protection from a broadcast/multicast/unicast storm
• IP-MAC-Port Binding (IMPB)
- Checking the ARP-packets
- Checking the IP-packets
- DHCP Snooping
- DHCPv6 Snooping1
- DHCPv6 Guard1
- IPv6 Route Advertisement (RA) Guard1
- IPv6 ND Snooping1
- IPv6 ND Inspection1
• Segmentation of traffic
• D-Link Safeguard Engine
• L3 Control Packet Filtering
• Filtering NetBIOS/NetBEUI
• DHCP Server Screening
• Filtering DHCP clients
• The prevention of ARP Spoofing
• Protection against attacks BPDU
• Prevention of DoS attacks
OAM
Cable Diagnostics
• 802.3 ah Ethernet Link OAM
• Dying Gasp
• 802.1 ag Connectivity Fault Management (CFM)
Management
• Web GUI (supports IPv4/IPv6)
• Command line interface (CLI)
• Telnet server/client (supports IPv4)
• TFTP/FTP-client (support IPv4)
• ZModem
• Logging of input commands
• IPv6 Neighbor Discovery
• SNMP v1/v2c/v3 (supports IPv4)
• SNMP Traps
• System log
- Max. number of entries in the log: 10 000
• SMTP (IPv4)
• RMON v1:
- Support for groups 1, 2, 3, 9
• RMON v2:
- Support Probe Config group
• 802.1 AB LLDP
- LLDP-MED
• BootP/DHCP-client (support IPv4)
• Automatically configure DHCP1
• DHCP Relay (support IPv4)
- DHCP Relay Option 60, 61 and 82
- DHCP Client Option 12
• Adding a tag PPPoE Circuit-ID1
• Supports multiple copies of SOFTWARE (Multiple Images)
• Supports multiple copies of configuration (Multiple Configurations)
• Flash file system
• Monitoring CPU
• Monitor memory
• SNTP (IPv4)
• Debugging commands
• Password recovery
• Password encryption
• Ping
• Traceroute
• Microsoft® NLB (network load Balancing) (support IPv4)
• Zero Touch Provisioning (ZTP)1
• sFlow1
• D-Link Network Assistant1
• Supports Real Time Clock (RTC)
Standarts MIB
• RFC1065, RFC1066, RFC1155, RFC1156, RFC2578
• RFC1212
• RFC1213
• RFC1215
• RFC1493, RFC4188
• RFC1157, RFC2571, RFC2572, RFC2573, RFC2574, RFC2575, RFC2576
• RFC1442, RFC1901, RFC1902, RFC1903, RFC1904, RFC1905, RFC1906, RFC1907, RFC1908, RFC2578, RFC3418, RFC3636
• RFC271, RFC1757, RFC2819
• RFC2021
• RFC1398, RFC1643, RFC1650, RFC2358, RFC2665, RFC3635
• RFC2668
• RFC2674, RFC4363
• RFC2618
• RFC4022
• RFC4113
• RFC3298
• RFC2620
• RFC2925
• RFC2465
• RFC2466
• RFC4293
• RFC3289
Physical parameters
Dimensions
• 280 x 140 x 44 mm
Weight
• 1,42 kg
Conditions
MTBF (hours)
• 762 952
Heat Dissipaiton
• 53,229 BTU/h
Power
100 to 240 VAC, 50~60 Hz
Max. power consumption
• 15,6 W
Power consumption in standby mode
• 9,8 W/In 100
• To 10.5 W/240 V
Ventilation system
• Passive
The static protection
• All Ethernet ports support the standard IEC61000-4-5 built-in protection against static electricity (up to 6 kV)
Temperature
• Operating: -5 to 50 °C
• Storage: -20 to 70 °C
Humidity
• operating: 0% to 95% non-condensing
• Storage: 0% to 95% non-condensing
The Kit
• DGS-1510-20L/ME
• 2 mounting bracket for installation in 19-inch rack
• Set of screws (8 PCs.) and rubber feet (4 PCs.)
• Connector for connecting to a backup power source
• Power cable
• Clamp for power cable
• Console cable
• Quick installation guide
• Setup CD-ROM
• Sticker with serial number
Other
EMI
• CE, FCC, C-Tick, VCCI, BSMI
Security
• cUL, CB
Çözümler
Sipariş Bilgisi
Görseller
DGS-1510-28L/ME
View from the right
Back view
Front view
İndir
Destek Merkezi
