Hızlı Arama
Ürün Özellikleri:
16 adet 10/100/1000 Mbps ve 2 adet 100/1000Base-T/SFP Port Yönetilebilir L2 Metro Ethernet Anahtar
Genel Özellikler:
Fiziksel Özellikler
Number of Ports
• 18 10/100/1000BASE-TX ports
Standards
• IEEE 802.3 compliance
• IEEE 802.3u compliance
• IEEE 802.3ab compliance
• IEEE 802.3x Flow Control
• IEEE 802.3az compliance
Performance
Switching Capacity
• 36 Gbps
64-byte Maximum Forwarding Rate
• 26.78 Mbps (based on 64 Bytes)
MAC Address Table Size
• 8K Entries
DRAM for CPU
• 128 MB
Packet Buffer
• 4.1 Mbit
Flash Memory
• 16 MB
Jumbo Frame
• Up to 10 Kbytes
LEDs
• Power (per device)
• Link/Activity/Speed (per port)
Power Consumption
Standby Mode
• 3.4 watts
Maximum
• 7.9 watts
Software Features
L2 Features
• MAC Address Table: 8K
• 802.3x Flow Control
  • HOL Blocking Prevention
• Loopback Detection
• Port Mirroring
  • Max 4 Mirror sessions
  • One-to-One
  • Many-to-One
L2 Multicasting
• IGMP Snooping
  • IGMP Snooping v1/v2, v3 Awareness
  • Supports 256 IGMP snooping groups (shared with MLD Snooping)
  • Host-based IGMP snooping Fast Leave
• IGMP Authentication
• MLD Snooping
  • MLD Snooping v1, v2
  • Supports 256 MLD snooping groups (shared with IGMP Snooping)
  • Host-based MLD Snooping Fast Leave
• Limited IP Multicast
VLAN
• 802.1Q Tagged VLAN
• VLAN Group
  • Supports 32 static VLAN groups
• Management VLAN
• Port-based VLAN
• ISM VLAN
• Double VLAN (Q-in-Q)
  • Port-based Q-in-Q
Quality of Service (QoS)
• 8 queues per port
• Queue Handling
  • Strict Priority
  • Weighted Round Robin (WRR)
• Bandwidth Control
  • Port-based (Ingress/Egress, min. granularity 16 Kb/s)
• CoS Based on:
  • 802.1p
  • DSCP
Security
• Port Security
  • Up to 64 MAC addresses per port
• Traffic Segmentation
• Broadcast/Multicast/Unknown Unicast Storm Control
• D-Link Safeguard Engine
AAA
• 802.1X
  • Port-based Access Control
  • Host-based Access Control
• Supports Guest VLAN
• Support Local/RADIUS Servers
• Support RADIUS Accounting
• 3 Levels of User Accounts
OAM
• Cable Diagnostics
• 802.3ah
Management
• Web-based GUI
• Command Line Interface (CLI)
• Telnet Server
• TFTP Client
• SNMP v1/v2c/v3
• SNMP Traps
• System Log
• RMON v1
  • Support 1,2,3,9 Groups
• LLDP
• DHCP Client
• DHCP Auto-Configuration
• DHCP Relay for IPv4/IPv6
• DHCP Relay Option 82
• DHCP Relay Option 37
• PPPoE Circult-ID Tag Insertion
• SNTP
• CPU Monitoring
• Password Encryption
MIB
• RFC1213 MIB II
• RFC1493 Bridge MIB
• RFC1907 SNMPv2 MIB
• RFC1398, 1643, 1650, 2358, 2665 Ether-like MIB
• RFC 2233, 2863 IF MIB
• Private MIB
IETF Standard
• RFC768 UDP
• RFC791 IP
• RFC792,2463, 4443 ICMPv4
• RFC793 TCP
• RFC826 ARP
• RFC 2474, 3260 Definition of the DS Field in the IPv4 and IPv6 Header
• RFC 1321, 2284, 2865, 3580, 3748 Extensible Authentication Protocol (EAP)
• RFC2571, RFC2572, RFC2573, RFC2574 SNMP
• RFC1981, RFC2460, RFC2461,4861, RFC2462,4862, RFC2464, RFC3513,4291, RFC2893,4213
Physical & Enviromental
Power Input
• External Power Adapter: 100 to 240 V AC, 50 to 60 Hz
• Output: 12 V/1 A
Size
• 190 x 120 x 38 mm (7.48 x 4.72 x 1.50 inches)
MTBF
• 706,061 hours
Acoustics
• 0 dB
Heat Dissipation
• 26.97 BTU/hr
Weight
• 0.63 kg
Ventilation
• Fanless
Operating Temperature
• -5 to 50 °C (23 to 122 °F)
Storage Temperature
• -40 to 70 °C (-40 to 158 °F)
Operating Humidity
• 10% to 90%
• EMI CE Class B, FCC Class B, VCCI, BSMI
• Safety CE LVD, UL/cUL, CB, BSMI
Ürünler | Destek  | Haberler  | Hakkında |
