Hızlı Arama
Ürün Özellikleri:
16 adet 10/100/1000 Mbps ve 2 adet 100/1000Base-T/SFP Port Yönetilebilir L2 Metro Ethernet Anahtar
Tanımlama:
D-Link’s Gigabit Metro Ethernet Switches are ideal for Metro Ethernet applications, providing
16/24 copper connections on upgraded Gigabit Ethernet ports along with Gigabit SFP ports for
improved uplink bandwidth if needed. They also offr resilience against electrical spikes with
built-in surge protection, giving you a reliable solution you can count onD-Link Green/Power Saving Performance
Compliant with IEEE802.3az Energy Effient Ethernet, these switches consume less energy by
cutting down on power consumption when port utilization is low. By deploying EEE devices,
users can cut operating costs and even cut down on necessary cooling equipment, helping
small and medium-sized businesses stay within their budgets. The DGS-1100/ME Series also
features D-Link Green Technology that helps automatically save energy. The switches monitor
the link status of every port and will drastically reduce power consumption when a port link is
down
Easy to deploy
The DGS-1100/ME Series support an intuitive D-Link Network Assistant Utility and a command
line management interface. The D-Link Network Assistant Utility allows customers to discover
all D-Link switches within the same L2 network segment. With this utility, users do not need
to change the IP address of their PC, and this also makes initial setup of the switches quick
and easy. Switches within the same L2 network segment that are connected to the user’s PC
are displayed on-screen for instant access. This allows for extensive switch confiuration and
basic setup of discovered devices, including password changes and fimware upgrades. The
command line interface enables network administrators to remotely control their network
down to the port level
QoS and Bandwidth Control
The DGS-1100/ME Series supports Auto Surveillance VLAN (ASV), and Auto
Voice VLAN, which are best suited for VoIP and video surveillance deploymentsAuto Surveillance VLAN consolidates data and surveillance video transmission
through a single DGS-1100/ME Series switch, thus sparing businesses the
expense of dedicated hardware and facilities. ASV also ensures the quality
of real-time video for monitoring and control without compromising the
transmission of conventional network data. The Auto Voice VLAN technology
enhances the VoIP service by automatically placing voice traff from an IP
phone to an assigned VLAN. With higher priority and individual VLAN, these
features guarantee the quality and security of VoIP traffi Bandwidth Control
can reserve bandwidth on a per port basis for important functions that
require larger bandwidth or might have high priority
PoE Support
The DGS-1100-24P/ME delivers Power over Ethernet (PoE) capabilities,
making deployment with IP cameras, VoIP phones, and access points much
easier. Power cords will become a thing of the past, as the DGS-1100-24P/ME
complies with the 802.3af/802.3at standard for PoE and supports a 100 Watt
power budget. The 10/100/1000Base-T Ethernet ports mean that even highquality video is no problem
Easy Troubleshooting
The DGS-1100/ME Series feature Loopback Detection and Cable Diagnostics
to help network administrators fid and solve network problems quickly and
easily. Loopback Detection is used to detect loops created by a specifi port
and automatically shut down the affcted port. The Cable Diagnostics feature
is designed for network administrators to quickly examine the quality of the
copper cables, recognize the cable type, and detect cable errors
Advanced Features
The DGS-1100/ME Series is equipped with advanced security features such
as Static MAC, Storm Control, and IGMP Snooping. Static MAC allows users to
create a MAC whitelist for specifi ports, helping administrators limit network
access to authorized devices only. Storm Control monitors broadcast,
multicast, or unknown unicast traff and will start blocking or discarding
packets which could flod the network when the defied threshold is
exceeded. IGMP Snooping is able to reduce the loading of L3 multicast
routers and save bandwidth in network throughput
Ürünler | Destek  | Haberler  | Hakkında |
