DES-1018PEOL
16 port 10/100BASETX (8 port PoE Destekli ) ve 2 combo 10/100/1000BASET/ SFP Port ile Yönetilmeyen Anahtar
Nereden Alınır
Tanımlama
Unmanaged Switch DES-1018P / DES-1018MP with 18 ports and supports PoE technology allows users to easily connect and supply power to the various PoE-compatible devices, such as wireless access points, network cameras, IP-phones. DES-1018P / DES-1018MP can be used to connect other Ethernet-devices, including computers, printers and network drives.
Supports IEEE 802.3af PoE
In the DES-1018P / DES-1018MP provides 8 or 16 ports with support for IEEE 802.3af PoE. Each PoE-port provides up to 15.4W with a total budget of 80 W (DES-1018P) or 246.4 W (DES-1018MP), which allows users to connect to the DES-1018P / 1018MP any device compatible with the IEEE 802.3 standard af. With support for PoE, you can reduce the cost of the additional settlement of the power cord and place network equipment in any hard to reach places, regardless of the location of electrical outlets.
The possibility of expanding the network
The presence of two Gigabit combo ports trunk can increase network capacity and provide fault-tolerant wire connection required for reliable data transmission, video surveillance and traffic of voice applications. This hardware-based solution helps to increase the bandwidth by using a high-speed Gigabit Ethernet connection on the basis of fiber-optic communication line or twisted pair.
Low energy consumption
Implemented in the DES-1018P / DES-1018MP support standard IEEE 802.3az energy efficiency will reduce operating costs. With this functional switch determines the status of the connection and provides automatically powers down ports. In addition, the switch supports JavaScript Smart Fan, the use of which allows you to automatically adjust the fan speed, which results in reduced power consumption and noise reduction. *
Easy to install
DES-1018P / DES-1018MP relates to devices Plug-and-Play and requires no configuration. Simply connect the switch to the network, and then connect it to a PC, then you can share files and make VoIP-calls. Supports auto polarity MDI / MDIX on all ports eliminates the need for crossover cables when connecting to another switch or hub.  Auto-negotiation on each port to determine the connection speed of a network device (either 10 or 100 Mbit / s) and perform an smart setting for optimal compatibility and performance. Combining the advantages of using technology PoE, high data rates, reliability and ease of installation, this unmanaged switch with 18 ports is an excellent choice for connecting PoE-compatible devices to the network.
* Save energy by using a functional IEEE 802.3az current scenario due to the use of the switch.
Genel Özellikler
Fiziksel Özellikler
Interfaces
• 16-port 10 / 100BASE-TX (8 ports support PoE)
• 2 combo ports 10/100 / 1000BASE-T / SFP
Standards
• IEEE 802.3 10BASE-T
• IEEE 802.3u 100BASE-TX
• IEEE 802.3z
• IEEE 802.3x flow control
Switching matrix
7.2 Gbit / s
Speed ​​forwarding 64-byte packets
5,36 Mbits / s
Switching Method
Store-and-forward
MAC-address table
8K
Packet Buffer
384 KB
Enhanced interface
Automatic detection of polarity MDI / MDIX on all ports
Indicators
• On the device: Power
• Per Port: Link / Act and Speed
• On PoE-port: Power fail, Power OK
Fan
• 1 fan
PoE standard
IEEE 802.3af
PoE-ports
Ports 1-8, up to 15.4 watts per port
PoE power budget
80 watts
Static electricity **
up to 2 kV for ports 1-8
Physical parameters
Dimensions
280 x 210 x 44 mm
Weight
1.78 kg
Power
Power Input: 100-240 VAC, 50-60 Hz
Power Consumption
• Max. Power consumption: 102.6 W (PoE enabled), 14.3 W (PoE off)
• Power consumption in standby mode: 7.1 W / 100 V; 8.3 W / 240 V
Temperature
• Operating: 0º to 40ºC
• Storage: -40º to 70ºC
Humidity
• Operating: 0% to 95% (non-condensing)
• Storage: 0% to 95% (non-condensing)
MTBF (hours)
• 395,864 hours
Heat Dissipation
• 349,9 BTU / h
Certificates
• FCC Class A
• CE
• CCC
• RoHS
• VCCI
• BSMI
• C-Tick
Security
• CB
• cUL
• LVD
• CCC
• BSMI
** ESD protection is provided only for ports with support for PoE.
Çözümler
Sipariş Bilgisi
Görseller
DES-1018P/A
Front view
Back view
İndir
Destek Merkezi
