DES-1018MPEOL EOS
16 Port 10/100BASETX ve 2 port combo 10/100/1000BASET/ SFP ile PoE destekli yönetilmeyen anahtar
Tanımlama
Unmanaged Switch DES-1018MP with 18 ports and supports PoE technology allows users to easily connect and supply power to the various PoE-compatible devices, such as wireless access points, network cameras, IP-phones. DES-1018MP can be used to connect other Ethernet-devices, including computers, printers and network drives.
Supports IEEE 802.3af PoE
In DES-1018MP provides 16 ports with support for IEEE 802.3af PoE. Each PoE-port provides power up to 15.4 watts of the total budget of 246.4 W, which allows users to connect to the DES-1018MP any device compatible with standard IEEE 802.3af. With support for PoE, you can reduce the cost of the additional settlement of the power cord and place network equipment in any hard to reach places, regardless of the location of electrical outlets.
The possibility of expanding the network
The presence of two Gigabit combo ports trunk can increase network capacity and provide fault-tolerant wire connection required for reliable data transmission, video surveillance and traffic of voice applications. This hardware-based solution helps to increase the bandwidth by using a high-speed Gigabit Ethernet connection on the basis of fiber-optic communication line or twisted pair.
Low energy consumption
Implemented in the DES-1018MP support energy efficiency standard IEEE 802.3az will reduce operating costs. With this functional switch determines the status of the connection and provides automatically powers down ports. In addition, the switch supports JavaScript Smart Fan, the use of which allows you to automatically adjust the fan speed, which helps to reduce energy consumption and reduce shuma.²
Easy to install
DES-1018MP relates to devices Plug-and-Play and requires no configuration. Simply connect the switch to the network, and then connect it to a PC, then you can share files and make VoIP-calls. Supports auto polarity MDI / MDIX on all ports eliminates the need for crossover cables when connecting to another switch or hub.
Auto-negotiation on each port to determine the connection speed of a network device (either 10 or 100 Mbit / s) and perform an smart setting for optimum compatibility and performance. Combining the advantages of using technology PoE, high data rates, reliability and ease of installation, unmanaged switch DES-1018MP with 18 ports is an excellent choice for connecting PoE-compatible devices to the network.
