DGS-1005D/H2EOL EOS
5 port 10/100/1000 Base-T ve güç tasarrufu fonksiyonlu Yönetilemeyen Layer 2 Gigabit Anahtar
Tanımlama
Gigabit speed data network
Gigabit Switch 5-port D-Link DGS-1005D provides data transfer and work online gaming at speeds up to 2000 Mbit / s. Indicators of two colors for each port to help you easily determine the status of the connection. DGS-1005D supports QoS, ensuring prioritization of delay-sensitive traffic and important for efficient transmission of multimedia data in real-time, high quality VoIP calls and online gaming.
Implementing technology D-Link Green
Switch DGS-1005D which supports plug-and-play is a device that uses D-Link Green, providing energy savings, reduced heat emission and a longer product life without sacrificing performance or functionality. The switch supports JavaScript IEEE 802.3az Energy-Efficient Ethernet (EEE), by which it is determined when the connected computer is turned off or when there is no Ethernet-traffic on and off power to the inactive ports, which saves a significant amount of energy. Also, the switch capable of adjusting the power consumption by determining the length of the cable connected to the port. Both of these features work together to automatically save energy.
Caring for the environment
5-Port Gigabit Switch DGS-1005D is designed to meet the requirements of environmental protection, in accordance with EnergyStar Level V and regulations, CEC and MEPS, requiring the use of power adapters that reduce power consumption. The switch also RoHS compliant restricting the use of hazardous substances and uses recyclable packaging that greatly reduces the amount of waste in accordance with Directive WEEE.
