DPS-800Proje
Chassis for redundant power supplies with 2 slots
Nereden Alınır
Tanımlama
DPS-800 chassis allows up to two modules DPS-200, DPS-300 or DPS-500/500DC in an equipment rack.
Using the chassis will save space and at the same time, the cable system will look neat. All RPS, installed in the chassis, connected directly to the power source and can be replaced in a "hot mode".
Genel Özellikler
Fiziksel Özellikler
Number of Slots
2-slot chassis
The physical parameters
Measurements
482 mm x 180 mm x 55 mm
Weight
1.06 kg
Çözümler
Sipariş Bilgisi
Görseller
DPS-800/A
Front view
İndir
Destek Merkezi
