DGS-3420-26SCEOL EOS
Tanımlama
The xStack DGS-3420 series of next generation Layer 2+ Gigabit switches delivers performance, flexibility, security, multi-layer QoS, and accessibility, along with redundant power solutions for SMBs and enterprises. With high Gigabit port densities, Gigabit SFP, 10-Gigabit SFP+ support, and advanced software solutions, these switches can act as either departmental access layer devices or aggregation switches to form a multilevel network structured with backbone and centralized high-speed servers. Service providers can take advantage of the high SFP density switches (such as DGS-3420-28SC/26SC) to structure the aggregation of Fiber to the Building (FTTB) networks that are extended to the subscribers’ sites.
		Unparalleled Flexibility
		Easily deployed and simple to manage, the DGS-3420 can be stacked with any switch that supports D-Link’s Single
		IP Management to form a multi-level network structured with backbone and centralized high-speed servers. The virtual stack can include units located anywhere on the same network domain, and uses optional 10-Gigabit uplinks to move intra-stack traffic at 20 Gbps full duplex speeds.
		Redundant Ring Stacking
		Alternatively, depending on whether linear or faulttolerant ring stacking is implemented, users can use one or two 10-Gigabit SFP+ ports to create a physical stack. 12 units or 576 Gigabit ports can be configured for a stack using direct attach cables to provide high-bandwidth on the DGS-3420 Series with cost efficiency.
		Security, Performance & Availability
		The DGS-3420 Series provides a complete set of security features including L2/L3/L4 multi-layer Access Control Lists and 802.1X user authentication via TACACS+ and RADIUS servers. The DGS-3420 Series offers extensive VLAN support including GVRP and 802.1Q VLAN to enhance security and performance. A robust set of L2/L3/L4 QoS/CoS solutions help ensure that critical network services such as VoIP, ERP, Intranet, and video conferencing are served with proper priority. The series also provides D-Link’s Safeguard Engine to increase the switch’s reliability, serviceability, and availability to prevent malicious flooding traffic caused by worms or virus infections. Bandwidth Control can be flexibly set for each port using pre-defined thresholds to assure a committed level of service for end users. For advanced applications, flow-based bandwidth control allows easy fine-tuning of service types based on specific IP addresses or protocols.
		IPv6 Technology
		The DGS-3420 Series also features comprehensive IPv6 support, including IPv6 Tunnel, ICMPv6, DHCPv6, RIPng,
		and more. With 10-Gigabit connectivity and IPv6 support, the series enables you to future-proof your network for cost efficiency and longevity while meeting the requirements that future IPv6 capable network devices require.
		D-Link Green Technology
		D-Link is striving to take the lead in developing innovative and power-saving technology that does not sacrifice operational performance or functionality. The DGS-3420 Series implements D-Link Green technology, which includes power saving through link status, smart fan design, increased heat dissipation, and cable length detection. The power saving feature automatically powers down ports that have no link or link partner. The Smart Fan design allows the built-in fans to automatically turn on only at a certain temperature, providing continuous, reliable, and eco-friendly operation of the switch.
Genel Özellikler
	Interface
	• 20 SFP ports
	• 4-port comb- 10/100/1000BASE-T/SFP
	• 2-port SFP +
	Reserve power supply
	• DPS-500
	Ports
	• Management console port: RJ-45
	• Control port: 10/100BASE-T
	• Signal port
	• Slot for SD-cards
	Performance
	• Switching matrix 88 Gb / s
	• The speed of packet forwarding: 65,47 Mpps
	• Buffer packets: 2MB
	• MAC-address table 16 K records
	• Routing table IP v4/v6: 1 K/512 records
	• Routing table IP v4/v6 L3: 2K/1K records
	• Size of Jumb- Frame: 13 000 bytes
	Fiziksel Özellikler
		MTBF (Hours)
		• 255 608
		Noise level
		• At operating temperatures below 30 ° C: <40.6dB, 30 ° C and more: <51.1dB
		Heat release
		• 276,2 BTU / hr
		Power Input
		• 100-240 VAC, 50/60Hz
		Max. power consumption
		• 81.0 Watt
		Dimensions
		• 441mm x 310mm x 44mm
		Weight
		• 5.07 kg
		Ventilation
		• Smart Fan (> 39 ˚ C: High-speed, <36 ˚ C: Low-Speed) 3
		Operating temperature
		• 0-50 ° C
		Storage temperature
		• -40-70 ° C
		Operating Humidity
		• 10% -90% RH
		Storage Humidity
		• 5% ~ 90% RH
		Emission (EMI)
		• FCC Class A, CE Class A, VCCI Class A, IC, C-Tick
		Security
		• CB, cUL, LVD
		Certificates
		• IPv6 Ready Logo Phase 2
