Description
SHARE YOUR PRINTER AND MULTIFUNCTION EQUIPMENT WIRELESSLY
The DPR-1040 Wireless G Print Server lets users share a USB printer across a network, while also providing scan and fax functions to those who use multifunction equipment. Use the WPS button neatly located on the side of the device to set up a secure wireless connection to your router or access point in seconds, giving you the time to enjoy the benefits of this stylish and compact device.
HIGH SPEED OPERATION
Equipped with a powerful CPU, large memory, high speed USB 2.0 port and up to 100Mbps network data transfer, this print server makes your operations fast and efficient. Printers attached to the DPR-1040 can print, scan, and fax at the same time, giving this device better performance than any software-based print server at a fraction of the cost.
ACCESS SECURITY AND MULTIPLE OS SUPPORT
The DPR-1040 provides all the necessary security you need by allowing the administrator to configure user access rights to the printer. It supports computers running the Windows 2000/XP/Vista and Apple Mac operating systems.
REMOTE PRINTING SUPPORT
The DPR-1040 supports the Internet Printing Protocol (IPP), enabling remote users to output to their printer even when they are away from the office. The print server also provides network administrators with critical information about the network printer. Regardless of where you are, with this print server never again worry about being unable to print out important files.
General features
STANDARDS
• IEEE 802.3
• IEEE 802.3u
• USB 2.0
• IEEE 802.11b
• IEEE 802.11g
DEVICE INTERFACES
• 802.11b/g wireless LAN
• 1 USB 2.0 port
• 1 10/100BASE-TX Ethernet LAN port
WIRELESS FREQUENCY RANGE
• 2.4GHz to 2.5GHz
WIRELESS ANTENNA TYPE
• PIFA antenna
WIRELESS SECURITY
• 64/128 bit WEP
• WPA/WPA2 (Wi-Fi Protected Access)
• WPS support (Wi-Fi Protected Setup)
DEVICE MANAGEMENT
• Through Internet Explorer v6 or later; or other Java-enabled browsers
• DHCP server and client
• Print Server setup and management program running under Windows
DIAGNOSTIC LEDS
• Power
• Ethernet
• USB
• Wireless
• WPS
Certificates
Order info
DPR-1040 WIRELESS G MULTIFUNCTION PRINT SERVER
