DWA-142EOL EOS
Description
ULTIMATE PERFORMANCE
The DWA-142 RangeBooster N USB adapter is a draft 802.11n client device that delivers unrivaled wireless performance for the PC. Users can easily upgrade to the next generation of wireless technology by adding this RangeBooster N adapter to access network high-speed Internet connection while sharing photos, fles, music, video, printers, and storage. Enhance Internet experience with a faster wireless connection and enjoy smooth digital phone calls, gaming, downloading, and video streaming.
GET CONNECTED, STAY CONNECTED
Powered by RangeBooster N technology, this adapter provides wireless performance that is up to 4 times farther than 802.11g.  This high performance wireless adapter is designed for use in bigger homes and for users that demand higher networking performance. Maximize wireless performance by connecting this adapter to a RangeBooster N router and stay connected from virtually anywhere in your home. It can also be used with 802.11g and 802.11b wireless networks to enable signifcantly improved reception. This adapter supports WPA/WPA2 security and WEP data encryption to help prevent outside
intrusion and protect your personal information from being exposed.
EASY TO SETUP, EASY TO USE
A Quick Setup Wizard guides users step-by-step through the installation process. Confgure this adapter without having to call a networking expert for help. The Wireless Manager is included with this product to keep track of all most frequently accessed networks. With unmatched wireless performance, reception, and security, this adapter is the best choice for easily adding or upgrading wireless connectivity to desktop computers.
General features
SYSTEM REQUIREMENTS
+  Windows XP SP2 or 2000 SP4
+  CD-ROM drive
+  20MB hard disk space
+  Available USB port
STANDARDS
+  IEEE 802.11n (draft)
+  IEEE 802.11g
+  IEEE 802.11b
+  USB 2.0
FREQUENCY RANGE
+  2412 to 2462MHz (North America)
+  2412 to 2472MHz (General Europe)
EMISSION SCHEMES
+  DSSS, OFDM
DATA MODULATION SCHEMES
DBPSK, DQPSK, CCK and OFDM
(BPSK/QPSK/16-QAM/64-QAM)
DATA RATES
+  802.11g: 6/9/12/18/24/36/48/54Mbps
+  802.11b: 1/2/5.5/11Mbps
+  802.11n: 30/60/90/120/180/240/270/300Mbps
TRANSMIT OUTPUT POWER
16dbm (typical)
ANTENNAS
+  Two integrated PIFA 2dBi Gain antennas
SECURITY
+  64/128-bit WEP data encryption
+  Wi-Fi Protected Access (WPA, WPA2)
OPERATING VOLTAGE
5VDC +/- 5%
POWER CONSUMPTION (802.11N)
+   TX: 460mA
+   RX: 270mA
+   Standby: 270mA
DIAGNOSTIC LEDS
+  Activity
DIMENSIONS
97.33 mm (diameter) x 19.30 mm
(height) (3.83 x 0.76 inches)
WEIGHT
95 grams (0.21 lb)
OPERATING TEMPERATURE
0º to 40º C
STORAGE TEMPERATURE
-20º to 65º C
OPERATING HUMIDITY
10% to 90% non-condensing
STORAGE HUMIDITY
5% to 95% non-condensing
CERTIFICATIONS
+  FCC Class B
+  CE
+  C-Tick
+  IC
Certificates
Order info
DWA-142 RangeBooster N USB 2.0/1.1 adapter is a draft 802.11n.
